Results 1 to 1 of 1
Thread: Adding footers in PDF fubars
    Cairo - no, not Illinois
    5,069
    Default Adding footers in PDF fubars
    I'm working with a remote partner who is finalizing a document submittal, combining 11x17 PDF drawings from Revit and CAD, and putting them inside the PDF multi-page document, that also has letter pages (text, narrative, specs, etc)
    Once in the final PDF doc, she is applying Footers using Acrobat pro. That works for the Revit produced drawings, and all the text documents, but the Civil3d-generated PDF files I'm sending her end up having the right several inches of the CAD linework blanked out. The footer shows up correctly on 11x17 page, but the drawing itself gets truncated -- roughly 11x11, missing the rightmost 6".
    I can't duplicate the problem here -- but am hoping someone else has experienced it, and might have a fix she can use.
    cheers,
    <update> I sent her a DWF print, which she converted to PDF from ADR, and that 'flavor' worked fine with footers applied in Acrobat.
  1. Have Footers Available for all Schedules
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2013-01-10, 02:06 AM
  2. 2013: How to adjust size of footers (slab end thickness)
    By awem in forum Revit Architecture - General
    Last Post: 2012-09-28, 03:08 PM
  3. adding one
    By prose in forum AutoLISP
    Last Post: 2008-11-18, 06:08 PM
  4. Can footers be copied from project to project?
    By DoTheBIM in forum Revit Architecture - General
    Last Post: 2008-04-30, 06:29 PM
  5. Headers & Footers for OLE Word doc
    By dpettyjohn in forum AutoCAD General
    Last Post: 2005-07-19, 06:48 AM
