Thread: Xref Repathing Utility
    2016-02
    4
    Question Xref Repathing Utility
    Hello all,
    A few years ago, I worked for a company that changed the name of it's servers and thus we had to repath all of the external reference paths. At the time, we found a 3rd party program that could do entire batches by selecting the project folders (the program located the dwg files) and basically do a remove/replace with the paths (S:\123456 to S:\100000 series\123456). It had some size limitations but could easily handle 50-100 dwg files at a time in a matter of a few minutes. Unfortunately, when I searched online for the same program it hasn't been updated since 2012.
    My new company is going to synchronized servers across offices and I am currently using the Reference Manager but am finding it to be too slow and clunky - maybe I am using it wrong. I want to be able to select a series of projects and change from I:\123456 to I:\1\123456. Another unfortunate situation is that not everyone saves xrefs to the same folders or even similar naming convention (as part of this process we are going to default project folders to help with housekeeping). Any suggestions for a 3rd party program?
    Thanks
    Michael
    100 Club a_meteni's Avatar
    2002-12
    Cairo
    138
    Default Re: Xref Repathing Utility
    Hi,
    We’re using Reference manager and it works well. We generally don’t use “ Add all xrefs” option. Rather we choose “Add only the first-level xrefs” and process each level in a separate cycle.
    Best Regards
    Ali
    2016-02
    4
    Thanks for the reply, Ali.
    I thought about your response and went back to review how I was using the Reference Manager ... I was not using it correctly for the purpose I needed.
    I am now using the Find and Replace instead of the Edit Selected Path, and it is performing the way I need. I can now change a batch of files that are not in the same xref folder location but are under the same project folder.
    Thanks again,
    Michael
    2001-12
    St. Louis
    5,231
    Quote Originally Posted by Mhilde75 View Post
    Thanks again,
    Michael
    Thanks for taking the time to update this thread with what worked for you. I'm sure future users will appreciate the information.
  1. Repathing xref with DBX acts erratic
    By vlee in forum AutoLISP
    Last Post: 2016-05-24, 08:59 PM
  2. Replies: 0
    Last Post: 2015-08-07, 05:37 PM
  3. Replies: 5
    Last Post: 2011-08-25, 07:54 PM
  4. Utility Labels Resets during Xref updates
    By tonycarcamo in forum AutoCAD Civil 3D - General
    Last Post: 2009-08-12, 06:21 PM
  5. xref repathing
    By Takuwind in forum CAD Management - General
    Last Post: 2007-12-18, 09:16 PM
Tags for this Thread
