Hey all,
Need a usage tip here. I have collinear segments that share an endpoint that I need become one segment. I cannot use polylines because the software I export DXF to does not support them.
Picture this: *----*----* needs to become *---------*
That point in the middle needs to go away and I cannot use polyline. The reason why I can't just keep the two segments is because it causes the robot that follows the DXF drawing stop and restart on each segment end, so one continuous segment is considerably faster.
Is there a command, macro, or AutoLISP code that I can use to achieve this?
Insight is appreciated.
Thanks!
