Thread: Spread Footing for curve retaining wall different hight
    2017-12
    Post Spread Footing for curve retaining wall different hight
    Hey Guys Quick question, I'm having problems trying to apply a foundation for this Curve retaining wall. I have to say that I did this wall
    with Component in situ> Wall> Swept Blend. But for some reason that is the only way I found to make this particular wall. Now my issue is
    the spread footing. Can some one help me out to setup this wall as a structural in order to apply the footing?
    2016-02
    Philippines
    5
    Default Re: Spread Footing for curve retaining wall different hight
    Is wall Architectural or Structural?
    2015-03
    As far as I know, you don't have an option to switch wall between structural/ architectural if it was created as an In-Place wall. My only suggestion is to use Structural Foundation slab and trace along wall faces with appropriate toe & heel offsets
    2009-06
    Dubai
    15
    Quote Originally Posted by antonbond View Post
    Yes. You are absolutely correct. Wall foundation is not working with for Model In-Place. Great idea, That is what I am following also. what about model In-Place just in case if you want.
    Thanks,
    Venkat.PR
  1. Retaining Wall With Footing Help
    By CADdancer in forum ACA General
    Last Post: 2009-10-20, 02:35 PM
  2. Foundation... Retaining Wall Footing with key?
    By lzaras in forum Revit Structure - General
    Last Post: 2008-09-30, 07:43 PM
  3. Structural Spread/Isolated Footing
    By AKDrafter in forum Dynamic Blocks - Sharing
    Last Post: 2007-10-17, 07:27 PM
  4. Replies: 3
    Last Post: 2006-08-03, 07:43 PM
  5. Flip Control for Retaining Wall Footing
    By jrichardson in forum Revit Structure - Wish List
    Last Post: 2006-04-11, 04:56 PM
