Page 6 of 6 FirstFirst ... 23456
Results 51 to 52 of 52
Thread: Lisp Legend
  1. #51
    2015-10
    Belgrade, Serbia, Europe
    564
    Default Re: Lisp Legend
    No (vl-position) don't require (vl-load-com)...
    Here is list of all (vl-load-com) independent functions and belong to Visual Lisp...
    VL-ACAD-DEFUN
    VL-ACAD-UNDEFUN
    VL-ARX-IMPORT
    VL-BB-REF
    VL-BB-SET
    VL-BT
    VL-BT-OFF
    VL-BT-ON
    VL-CATCH-ALL-APPLY
    VL-CATCH-ALL-ERROR-MESSAGE
    VL-CATCH-ALL-ERROR-P
    VL-CMDF
    VL-CONSP
    VL-DIRECTORY-FILES
    VL-DOC-EXPORT
    VL-DOC-IMPORT
    VL-DOC-REF
    VL-DOC-SET
    VL-EVERY
    VL-EXIT-WITH-ERROR
    VL-EXIT-WITH-VALUE
    VL-FILE-COPY
    VL-FILE-DELETE
    VL-FILE-DIRECTORY-P
    VL-FILE-RENAME
    VL-FILE-SIZE
    VL-FILE-SYSTIME
    VL-FILENAME-BASE
    VL-FILENAME-DIRECTORY
    VL-FILENAME-EXTENSION
    VL-FILENAME-MKTEMP
    VL-GET-RESOURCE
    VL-INFP
    VL-INIT
    VL-LIST->STRING
    VL-LIST-EXPORTED-FUNCTIONS
    VL-LIST-LENGTH
    VL-LIST-LOADED-VLX
    VL-LIST*
    VL-LOAD-ALL
    VL-LOAD-COM
    VL-LOAD-REACTORS
    VL-MEMBER-IF
    VL-MEMBER-IF-NOT
    VL-MKDIR
    VL-NANP
    VL-POSITION
    VL-PRIN1-TO-STRING
    VL-PRINC-TO-STRING
    VL-PROPAGATE
    VL-REGISTRY-DELETE
    VL-REGISTRY-DESCENDENTS
    VL-REGISTRY-READ
    VL-REGISTRY-WRITE
    VL-REMOVE
    VL-REMOVE-IF
    VL-REMOVE-IF-NOT
    VL-SOME
    VL-SORT
    VL-SORT-I
    VL-STRING->LIST
    VL-STRING-ELT
    VL-STRING-LEFT-TRIM
    VL-STRING-MISMATCH
    VL-STRING-POSITION
    VL-STRING-RIGHT-TRIM
    VL-STRING-SEARCH
    VL-STRING-SUBST
    VL-STRING-TRANSLATE
    VL-STRING-TRIM
    VL-SYMBOL-NAME
    VL-SYMBOL-VALUE
    VL-SYMBOLP
    VL-UNLOAD-VLX
    VL-VBALOAD
    VL-VBARUN
    VL-VLX-LOADED-P
    VLARTS-INIT
    VLAX-ADD-CMD
    VLAX-FOR
    VLAX-REMOVE-CMD
    VLISP-DCLRES-LIST
    VLISP-DCLRES-LOAD-DIALOG
    VLISP-EXPORT-SYMBOL
    VLISP-FASRES-LIST
    VLISP-FASRES-LOAD
    VLISP-IMPORT-EXSUBRS
    VLISP-IMPORT-SYMBOL
    VLISP-INIRES-LIST
    H
  2. #52
    2017-10
    Florida
    26
    Thanks to everyone that replied to this thread, I have figured out how to exclude items that are not in the external file. Below is part of the routine. I hope this helps someone else in the future. User dlanor's post gave me the light bulb I needed to fix the routine. Thanks.
    (setq lfile (open "z:\\_CAD\\LISP\\LEGENDBLOCKS.TXT" "r"))
    (setq
    	n (length styleList)
    	cnt 1
    	index 0)
    (repeat n
    	(setq bname (nth index styleList))
    	(setq bdesc (cadr (assoc bname bllist)))
    	(if (not (assoc bname bllist))
    		(progn
    		(setq cnt (1+ cnt)
    		index (1+ index))
    		);end progn
    	(progn
    	(command-s "insert" bname
                 (setq cbp (polar bbp (/ (* 270 PI) 180) (* cnt (/ lf 3))))
                 lf
                 0.0
       (if (= curh 0.0)
    		(command-s "TEXT" "j" "ml"
                 (polar cbp 0 (/ lf 1.6))
                 (* lf 0.08)
                 0.0
                 (STRCAT "= " BDESC)
                 0.0
                 (STRCAT "= " BDESC)
    	);end if
    		(setq cnt (1+ cnt)
    		index (1+ index))
    	); end progn
    );end repeat
  1. Replies: 5
    Last Post: 2016-01-10, 04:44 PM
  2. Replies: 7
    Last Post: 2014-05-15, 03:00 PM
  3. Tags in Legend Views / Tag legend components
    Last Post: 2012-11-14, 07:08 AM
  4. Replies: 3
    Last Post: 2012-05-07, 08:16 PM
  5. Copy / Paste from Legend to Legend
    By antman in forum Revit Architecture - General
    Last Post: 2011-04-12, 03:22 PM
