Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 52
Thread: Lisp Legend
  1. #31
    2010-06
    962
    Default Re: Lisp Legend
    Quote Originally Posted by _brxdvs View Post
    yes that is one of the point styles
    Good to hear that.
    Please add the full line of codes as follows:
     (setq name (vlax-get-property pntstyle 'name))
    Below your line of codes as follows:
     (setq pntstyle (vlax-get point 'style))
    Like this ...
    ... into your previous complete routine.
    So the variable 'name' should have the name of the point style.
    Hope this clear enough to you otherwise just ask if you stuck with any.
  2. #32
    2017-10
    Florida
    26
    Thank you sir!
    got this:
    Command: POINTTEST
    ("VLT")
    one element solved!
    next step, how do I "filter" the list to just get unique names? as in no repeating styles, just capture one instance of each point style.
  3. #33
    2010-06
    962
    Thank you sir!
    You are welcome.
    As I have did in post no# 15 HERE so just use member function against your list with cons function.
    EDIT: Next time when you copy and paste codes that is not yours then it would be a respectful manner to give credits to authors / owners.
  4. #34
    2010-06
    962
    Quote Originally Posted by Tharwat View Post
    I meant THIS THREAD
  5. #35
    2017-10
    Florida
    26
    my apologies.
  6. #36
    2017-10
    Florida
    26
    this works now
    (defun c:pointtest2 (/ pntSel index pntStyle styleList)
      (if (setq pntSel (ssget "_X" '((0 . "AECC_COGO_POINT")))) ;selects all cogo points in drawing
        (repeat (setq index (sslength pntSel))
          (or (member (setq pntStyle (vlax-get-property (vlax-get (vlax-ename->vla-object (ssname pntSel (setq index (1- index)))) 'style) 'name)) styleList)
              (setq styleList (cons pntStyle styleList))
          );end or
        );end repeat
      );end if
      (print styleList);used for testing delete before final
      (princ)
    ) (vl-load-com)
    thanks for all your help!
  7. #37
    2010-06
    962
    Following your way of coding.
    (defun c:pointtest (/ selpnt n index pntlist point pntstyle stylelist pntname)
      (if (setq selpnt (ssget "X" '((0 . "AECC_COGO_POINT")))) ;selects the cogo points
        (progn
          (setq n (sslength selpnt))
          (setq index 0)
          (repeat n
            (setq pntlist (entget (ssname selpnt index)))
            (setq point (vlax-ename->vla-object (cdr (assoc -1 pntlist))))
            (setq pntname (vlax-get-property pntstyle 'name))
            (if (not (member pntname stylelist))
              (setq stylelist (cons pntname stylelist))
            (setq index (1+ index))
          (print stylelist)
      (princ)
    ) (vl-load-com)
  8. #38
    2017-10
    Florida
    26
    Thanks for your help Tharwat!
  9. #39
    2010-06
    962
    You are welcome anytime.
  10. #40
    2017-10
    Florida
    26
    So, opened a new drawing and I am getting this error: ; error: bad argument type: VLA-OBJECT nil when using the code from yesterday.
    I think it has to do with some cogo points that don't have styles applied and are set to default, is there a way to exclude nil values?
  1. Replies: 5
    Last Post: 2016-01-10, 04:44 PM
  2. Replies: 7
    Last Post: 2014-05-15, 03:00 PM
  3. Tags in Legend Views / Tag legend components
    Last Post: 2012-11-14, 07:08 AM
  4. Replies: 3
    Last Post: 2012-05-07, 08:16 PM
  5. Copy / Paste from Legend to Legend
    By antman in forum Revit Architecture - General
    Last Post: 2011-04-12, 03:22 PM
Tags for this Thread
