Thread: Layer states - can we save the states out ?
    I could stop if I wanted to Chirag Mistry's Avatar
    2004-06
    Atlanta
    254
    Exclamation Layer states - can we save the states out ?
    Team,
    I'd like to know if there is an operation in ACAD2005 or ADT3.3 that allows me to save viewing preferences for layers. I have a consultant drawing xrefed into another file, but only want certain layers visible. Since they send us these same files on a regular basis, I have to go through the process of freezing the same layers each time. Is there a way to streamline and save this state and transfer to subsequent files with identical layer names?
    150700
    3,421
    Default Re: Layer states - can we save the states out ?
    Hi Chiragmitry (sorry, don't know your real name)
    Please note I've *moved* this thread from the AutoCAD Tips and Tricks Forum to this one as I believe it would be better served here.
    Thanks
    100 Club jhohman's Avatar
    2003-08
    Spring Hill, Florida
    195
    What software are you using? In AutoCAD2005, you can set the layer state, then right-click in the layer list and select the "Save Layer State" option, this info is stored in the drawing and carries through to newer versions. I have drawings I did about 6 years ago and I can still restore the layer states from when the drawing was created in R14. Hope this helps.
    I could stop if I wanted to tyshofner's Avatar
    2004-03
    Dallas, Tx
    229
    Also, once you have saved your layer state, you can then export that state to an external file "*.las" that can then be imported into any drawing you choose.
    Ty
    2001-03
    13,499
    Hi
    Have a browse of the following threads -
    Layer State Mgr in 2004...
    i want to extract layer info...
    Have you tried the Forum Search facility, below a few key-word search examples:
    Layer + *las*
    Layer + *lay*
    Layer + *State*
    Lman
    Have a good one, Mike
  1. Layer States to Visibility States?
    By Ant59 in forum AutoCAD General
    Last Post: 2009-07-07, 11:17 AM
  2. Setvar to save layer states for views?
    By tedg in forum AutoCAD General
    Last Post: 2008-02-26, 09:29 PM
  3. express layer states or layer states
    By rstiles in forum AutoCAD General
    Last Post: 2007-08-23, 02:01 PM
  4. Save Layer States and restore
    By Matt Mercer in forum AutoLISP
    Last Post: 2005-02-24, 10:08 PM
