tadthurston725387
I was trying to use the end grips to lengthen the line. This only works with level lines, at least in the 2017 version. What I figured out though is that if you create the line with the "Create Line from Point Objects" command, them select the cogo points, a 3D line is created that you can extend or lengthen with grips just like a level line. It somehow overrides the requirement to be a level line.
In the spirit of AUGI, passing on information.
All lines are 3D, look in Properties and you will see X, Y, & Z values for each endpoint.
Old routine to modify the length of a line using horizontal distances, or to an elevation, or by a Percent or Ratio.
;| Change the Length of a Line|;
; BY: Tom Beauford
; BeaufordT@LeonCountyFL.gov
; Leon County Public Works Engineering
;(or C:chl (load "ChgLen.lsp"));chl
; (load "ChgLen.lsp") chl
(defun C:chl (/ ActDoc A pick B etype pt1 pt pt2 pt3 pt4 distold dist1 ang1 z1)
(setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(vla-StartUndoMark ActDoc)
(setq A (entsel "\nSelect Entity: ")
pick (osnap (cadr A) "endp")
B (entget (car A))
etype (cdr(assoc 0 B))
); setq
(princ "\netype = ")
(princ etype)
(cond
((eq etype "LINE")
(progn
(setq pt1 (cdr (assoc 10 B)) pt2 (cdr (assoc 11 B)))
(if (>(distance pt1 pick)(distance pick pt2))
(setq pt pt1 pt1 pt2 pt2 pt)
(setq pt3 (list (car pt1)(cadr pt1)) pt4 (list (car pt2)(cadr pt2))
distold (distance pt3 pt4)
ang1 (angle pt2 pt1)
(princ "\nOld Distance=")
(princ distold)
(initget "Lengthen Shorten Total Elevation Percent Ratio")
(if(= ¦¦global¦¦ nil)(setq ¦¦global¦¦ "Total"))
(if(setq ¦¦notnil¦¦ (getkword (strcat " [Lengthen/Shorten/Total/Elevation/Percent/Ratio] <" ¦¦global¦¦ ">: ")))(setq ¦¦global¦¦ ¦¦notnil¦¦))
(setvar "cmdecho" 0)
(cond
((= ¦¦global¦¦ "Lengthen")
(setq dist1 (+ distold (getreal "\nEnter Distance: "))
z1 (+(caddr pt2)(*(/ dist1 distold)(-(caddr pt1)(caddr pt2))))
); Lengthen
((= ¦¦global¦¦ "Shorten")
(setq dist1 (- distold (getreal "\nEnter Distance: "))
); Shorten
((= ¦¦global¦¦ "Total")
(setq dist1 (getreal "\nEnter New Length: ")
); Total
((= ¦¦global¦¦ "Elevation")
(setq z1 (getreal "\nEnter Elevation to Trim/Extend: ")
dist1 (*(/ distold (-(caddr pt1)(caddr pt2)))(- z1 (caddr pt2)))
); Elevation
((= ¦¦global¦¦ "Percent")
(setq z1 (+(caddr pt2)(* distold(getreal "\nEnter Slope in %: ")0.01))
dist1 distold
); Percent
((= ¦¦global¦¦ "Ratio")
(setq z1 (+(caddr pt2)(/ distold(getreal "\nEnter Run/Rise: ")))
dist1 distold
); Ratio
); cond
(setq pt1 (polar pt2 ang1 dist1)
pt1 (list (car pt1)(cadr pt1) z1)
(if pt (setq pt pt1 pt1 pt2 pt2 pt))
(setq B (subst(cons 10 pt1)(assoc 10 B) B)
B (subst(cons 11 pt2)(assoc 11 B) B)
(entmod B)
(princ distold)
(princ ", New Distance=")
(princ dist1)
); progn
); line
((or(eq etype "ARC")(eq etype "POLYLINE")(eq etype "LWPOLYLINE"))
(progn
(command "lengthen" pick)
); progn
); ARC, POLYLINE or LWPOLYLINE
); cond
(vla-EndUndoMark ActDoc)
(princ)
