Thread: Block Insertion Lisp/ Palette command - - HELP!
    2008-10
    46
    Default Block Insertion Lisp/ Palette command - - HELP!
    I'm trying to create what should be a very simple lisp routine, or maybe something that can just be put into the pallet as a macro command. Either way; I'm happy as long as it works.
    I need to insert a block named grdot into the drawings, but there are variables. I need it to match the annotation scale, plus a user input prompt for either sheet size B, or D.
    If it's D size, then the block needs to be inserted at twice the annotation scale, for B size, it would just need to be scaled at the annotation scale.
    I'm not having any luck figuring it out and and I'm relatively new at lisp.
    2005-06
    CORDOBA-ARGENTINA
    275
    Default Re: Block Insertion Lisp/ Palette command - - HELP!
    Please upload a sample.dwg
    2003-07
    555
    You could write it all in one line or what would be better would be to use a lisp that you pass the block name.
    not tested
    macro
    ^c^c^p(if (not insblk)(load "insblk"))(insblk "grdot"))
    lisp file
    (defun insblk (bname  / sheet sz )
    (setq sheet (strcase (getstring "Enter sheet size B or D")))
    (cond
    ((= sheet "B")(setq sz 2.0))
    ((= sheet "D")(setq sz 1.0))
    (command "-insert" (getpoint) bname sz 0.0)
  1. Simulate Palette Block Insertion
    By LSElite in forum AutoLISP
    Last Post: 2015-03-19, 10:41 PM
  2. block insertion from palette overwrites existing
    Last Post: 2014-10-29, 01:29 PM
  3. Block Insertion Errors from Tool Palette
    By DWS44 in forum AutoCAD General
    Last Post: 2008-05-20, 02:08 PM
  4. Dynamic Block Match Object Layer on insertion from Tool Palette
    By sfanello in forum Dynamic Blocks - Technical
    Last Post: 2007-08-02, 08:20 PM
  5. Add Block insertion macro to a Tool Palette
    By bboss in forum AutoCAD Customization
    Last Post: 2007-05-09, 07:13 PM
