Thread: Revit Export CAD options
    2017-05
    San Diego, CA
    Default Revit Export CAD options
    I was wondering if there was a way to make my exported CAD files have "blocks" instead of Xref's. This causes trouble because i then have to go into every file and bind everything, it is fine if i had 5-10 files but instead i have 60+. I would be very grateful if someone could help me out. Thanks in advance.
    i found the solution to my problem.
    2002-09
    Madison, WI
    5,687
    Default Re: Revit Export CAD options
    All depends on what you want.
    If you don't care if you're links have Individual layers that you can control after the fact, then no worries and just don't check the box to convert linked files as xrefs.
    If you need that function you'll need a 2 step process.
    Export with Xrefs and then write a script to bind as a bind.
    I'd use Script-Pro myself.
    Option B would be to use the Action Recorder inside Autocad and then Play it back, but you'll have to do that on a file by file basis.
  1. Revit export options defaults
    By jasonp in forum Revit Architecture - General
    Last Post: 2010-11-30, 10:51 PM
  2. Export Options?
    By Dave F. in forum ACA General
    Last Post: 2008-04-08, 04:22 PM
  3. IFC export options
    By pmourik in forum Revit - Plotting/Printing/Exporting
    Last Post: 2008-04-03, 06:47 AM
  4. improved dwg dwf export: export design options in hierachical way
    By studiodd in forum Revit Architecture - Wish List
    Last Post: 2007-02-28, 11:15 AM
  5. Be Able to Export Options to a File
    Last Post: 2006-05-12, 03:12 AM
