Results 1 to 8 of 8
Thread: Creating dwg files (dwg format) using Excel sheet.
    2018-01
    6
    Default Creating dwg files (dwg format) using Excel sheet.
    I have a Excel sheet showing around 500 drawings numbers and i would like to create just dwg files with the same drawings numbers as shown in excel. any help in this regards will be highly appropriated.
    Turlock, CA
    6,420
    Default Re: Creating dwg files (dwg format) using Excel sheet.
    If you search this forum for "Excel", you should find plenty of code to get you started and then you could come back and ask specific questions if you run into trouble.
    C:> ED WORKING....
    LinkedIn
    2018-01
    6
    Well, honestly speaking its difficult for me to write a code as i have no experience is programming, and you could imagine how difficult it is to understand and write a code when someone have no experience. if i start learning and then write code it might be too late considering my project deadline.
    Earth
    9,805
    I don't understand the request.
    What are "500 drawings numbers"?
    Is this a list of integers, such as 8, 15, 34, 2008, 3454, 5676, etc?
    And you want to create DWG files from some sort of data. Do you have AutoCAD or some other application or stub that will create DWG files?
    R.K. McSwain | CAD Panacea |
    2018-01
    6
    @ rkmcswain i have list of 500 drawing in Excel sheet, like
    AM-XXX-ELSS-P-210AP29-00001-0
    AM-XXX-ELSS-P-210AP29-00002-0
    AM-XXX-ELSS-P-210AP30-00003-0 etc
    i want to create just empty drawings using any template for these 500 drawings numbers listed in Ms office using Excel or any other software. The purpose is to have drawings with drawing references as shown in Excel sheet.
    The purpose of generating these files are that i have to delete these files from my project folder/sub folders/sub folders, i have a workaround that if i have these files in one folder with the same file reference i could find the identical in both folders and then i can delete from the project folder, i know its not the best way to delete but since i don't know how i can delete these 500 drawings at once i can manage in this way.
    2003-07
    561
    See the answer here and the other post, are you using multiple names or is this a school assignment ?
    http://www.cadtutor.net/forum/showth...ng-Excel-sheet.
    2018-01
    6
    i posted question in both forums. if it gets deleted i have no problem.
    Quote Originally Posted by Ponting View Post
    Can you post the Excel Sheet and Template ?
  1. A Different Excel Table Format Problem?
    By mdemint in forum AutoCAD General
    Last Post: 2008-04-29, 02:45 PM
  2. Linking Excel Sheet in IDW with an Excel Sheet in IPT
    By Darkstar24 in forum Inventor - General
    Last Post: 2008-04-20, 06:14 PM
  3. Saving multiple DWG 2007 format files to DWG 2000 format
    By waghorne in forum AutoCAD Customization
    Last Post: 2006-09-07, 05:22 PM
  4. AutoCAD 255 colors in excel format
    By johan d in forum CAD Management - General
    Last Post: 2006-05-15, 03:37 AM
  5. Replies: 3
    Last Post: 2006-05-12, 07:10 PM
