Smoke Compartment Object
Summary: I have concluded that while I can use Spaces/Zones and /or Areas they appear fundamentally different when considering typical real world scenarios
Description: As accurate Sq Footage is critical to calculate proper Life Safety documentation either more granular control of the bounding box (IE. Wall face, CL etc..) or more likely a unique object because more then likely the perimeters will seldom be identical throughout a typical building (This would hold true for Spaces or Zones or Areas). This would begin to lay a foundation for mature Fire Suppression systems ultimately leading to Virtual Fire scenarios for analysis when something can still be done to correct without blindsiding contractors and all other real world participants.
Product and Feature: Revit Architecture - Rooms
Submitted By: dekip007 on 01/17/2018
- You may not post replies
- You may not edit your posts
Forum Rules
