Thread: How long is too long?
    2006-04
    466
    Default How long is too long?
    When I use this program, there's no way to stop it.
    I've been thinking of measuring the character length with STRLEN of Phrase$ and denying any that are too long.
    My question is how long is too long, and how short is too short?
    Or is there a way of canceling the routine in the middle?
    I've also been thinking of using SUBSTR to shorten the string length.
    (defun c:SayIt ()
     (setq Phrase$ (getstring T "Enter string: "))
     (setq Phrase$l (strlen Phrase$))
     (if (< Phrase$l 256)
      (progn
       (vl-load-com)
       (setq sapi (vlax-create-object "Sapi.SpVoice"))
       (vlax-invoke sapi "Speak" Phrase$ 0)
       (vlax-release-object sapi)
     ));end progn/if
    );defun c:SayIt
    2006-04
    466
    Default Re: How long is too long?
    So, I settled for this. Now the program limits the character length to 1000, which takes less than 1.5 minutes to read.
    (defun c:SayIt ()
     (if (> Phrase$l 1000) (setq Phrase$ (substr Phrase$ 1 1000)))
     (vl-load-com)
    );defun c:SayIt
  1. 2011: lat long to v&h
    By mytt in forum AutoCAD General
    Last Post: 2013-05-07, 04:29 PM
  2. How long does it take? or ROI...
    By dandlf in forum Revit Architecture - General
    Last Post: 2009-02-18, 11:00 AM
  3. Long, long list of Keywords
    By rjcrowther in forum Revit - API
    Last Post: 2007-12-10, 08:22 AM
  4. How long does this take.....
    By DoTheBIM in forum Revit Architecture - General
    Last Post: 2005-03-09, 08:04 PM
