Thread: Don't want to have to restart when clicking a NON-polyline - CODE
    2018-02
    2
    Question Don't want to have to restart when clicking a NON-polyline - CODE
    Hey guys,
    I am very familiar with VBA, but not so much LISP. I have "inherited" a project where the user specifies arguments (Inverters, Strings, Panels; it is a solar energy project), then clicks on the line/polyline and it automatically creates multi-line text labeling each solar panel with the correct information. Currently, however, if you start this process, then "miss" clicking on a line/polylilne, the user has to restart the function. I have tried to convert this to VBA, but cant seem to find the correlating syntax for some (much) of the code. The code is listed below and ALSO ATTACHED - "INCS" (increment solar):
    (defun C:INCS (/ Inum Snum Pnum entlst entmat entnew entlst entlst2 entlst3 lst y)
      (setq Inum (getint "Enter Inverter Starting Number:"))
        (if (>= Inum 1) (setq Inum Inum) (setq Inum 1))
      (setq Imax (getint "Enter Max Number of Inverters:"))
        (if (>= Imax 1) (setq Imax Imax) (setq Imax 1))
      (setq Snum (getint "Enter String Starting Number:"))
        (if (>= Snum 1) (setq Snum Snum) (setq Snum 1))
      (setq Smax (getint "Enter Max Number of Strings on Inverter:"))
        (if (>= Smax 1) (setq Smax Smax) (setq Smax 1))
      (setq Pnum (getint "Enter Panel Starting Number:"))
        (if (>= Pnum 1) (setq Pnum Pnum) (setq Pnum 1))
      (setq Pmax (getint "Enter Max Number of Panels on String:"))
        (if (>= Pmax 1) (setq Pmax Pmax) (setq Pmax 1))
      (while (<= Pnum Pmax)
        (setq entlst (nentsel "\nSelect Line/Polyline in Block :")
           lst    (apply 'append
                         (mapcar '(lambda (x)
                                   (if (or (= 10 (car x)) (= 11 (car x)))
                                    (list
                                     (append (list (+ (* (car (nth 0 (setq entmat (caddr entlst)))) (cadr x))
                                                      (* (car (nth 1 entmat)) (caddr x))
                                                      (car (nth 3 entmat))))
                                             (list
                                              (+ (* (cadr (nth 0 entmat)) (cadr x)) (* (cadr (nth 1 entmat)) (caddr x)) (cadr (nth 3 entmat))))))))
                                 (if (= "POLYLINE" (cdr (assoc 0 (entget (setq entlst2 (cdr (assoc 330 (entget (car entlst)))))))))
                                  (progn (setq entnew entlst2)
                                         (while (/= "SEQEND" (cdr (assoc 0 (entget entnew))))
                                          (setq entnew (entnext entnew))
                                          (setq entlst3 (cons (reverse (cdr (reverse (assoc 10 (entget entnew))))) entlst3))))
        (setq Istring (strcat "I"(itoa Inum)))  				;concants the letter I and the number
        (setq Sstring (strcat "S"(itoa Snum)))				;concants the letter S and the number
        (setq Pstring (strcat "P"(itoa Pnum)))				;concants the letter P and the number
        (command "._mtext" (setq y (mapcar '/ (mapcar '+ (car lst) (caddr lst)) '(2 2)))
              "_j" "_mc" "_r"
              (* 180 (/ (car (vl-sort (mapcar 'angle lst (cdr lst)) '<)) pi)) y Istring Sstring Pstring "")
        (setq Pnum (+ Pnum 1))
        (if (and (> Pnum Pmax) (< Snum Smax)) (and (setq Snum (+ Snum 1)) (setq Pnum 1)))                                   ;if the panel number is less than the max and the string number is less than the max, then increment the string number by 1 and set the panel number to 1
        (if (and (> Pnum Pmax) (= Snum Smax) (< Inum Imax)) (and (setq Inum (+ Inum 1)) (setq Snum 1) (setq Pnum 1)))
      )        ;ends the while statement
    )        ;ends the INCSOLAR command
    If anyone has any ideas so that this function continues, even when the user "misses" clicking a line/polyline, OR if anyone can tell me the best way to convert this to VBA (cannot find the equivalent of "NENTSEL", don't know what is happening at the "mapcar '(lambda (x)"/etc.), it would be much appreciated.
    thanks,
    Rob
    2003-07
    560
    Default Re: Don't want to have to restart when clicking a NON-polyline - CODE
    If you use a while you can do a couple of things a hard pick and repick till you actually pick or ask did you miss do again.
    ; hard version
    (setq ans "Y")
    (while  (= ans "Y") (setq entlst (nentsel "\nSelect Line/Polyline in Block :")
    (if (= entlst nil)(Alert "Missed pick a bit more carefull")
    (setq ans "N")
    2018-02
    2
    Thumbs up Re: Don't want to have to restart when clicking a NON-polyline - CODE
    Thanks AL; Ended up using the "ERRNO" var; This is how it ended up...
    ;Rob Benz
    ;	- Solar panel string increment number function
    ;02.15.2018
    ;	- Added feature: hitting [SPACEBAR] will draw strings/wires in the same
    ;	  order that each panel was selected & labeled
    ;02.16.2018
    ;	- Added "MakeCircles", "LabelCircles", and "TrimCircle" functions
    ; This function lets user click on each panel and then
    ; labels the panels correctly: Inverter#,String#,Panel#
    (defun C:INCS (/ Inum Snum Pnum entlst entmat entnew entlst entlst2 entlst3 lst y dist)
        	(vl-load-com)		; loads extended functions/utilities/etc. if not already loaded
      	(setq *ptList* nil)	; RESET all global vars used
      	(setq *fPanel* nil)
      	(setq *lPanel* nil)
      	(setq *tmp1* nil)
      	(setq *tmp2* nil)
      	(defun DrawLines (lt /)		; draw lines\strings between each panels
    		(prompt "\nDrawing Lines...")
    	  	(setq lt(reverse lt))
    	  	(setvar "clayer" "E-NEW-POWER-EQUIP")
    	  	(command "._LINE")
    	  	(apply 'command lt)
    	  	(command "")
    	  	(setvar "clayer" "M-GEN-NOTES")
    	  	(prompt "\nLines Drawn.")
    	  	(setq lt nil)
    	  )		; END of defun DrawLines
    	(setvar "clayer" "M-GEN-NOTES")		;set layer to default PSI "M-GEN-NOTES" (color = yellow)
    	(setq Inum (getint "Enter Inverter Starting Number:"))	;get starting Inverter #
    	(if (>= Inum 1) (setq Inum Inum) (setq Inum 1))		; these are incase user input 0 or negative int
    	(setq Imax (getint "Enter Max Number of Inverters:"))	;get MAX # Inverters
    	(setq Snum (getint "Enter String Starting Number:"))	;get starting String #
    	(setq Smax (getint "Enter Max Number of Strings on Inverter:"))	;get MAX # Strings
    	(setq Pnum (getint "Enter Panel Starting Number:"))	;get starting Panel #
    	(setq Pmax (getint "Enter Max Number of Panels on String:"))	;get MAX # Panels
    	(setvar "ERRNO" 0)		; set system var to zero
      	(setvar "clayer" "M-GEN-NOTES")		;make sure that we start with the correct PSI "layer"
    	(while (<= Pnum Pmax)		;while panel # is <= to MAX panels, loop
    		(setq entlst (nentsel "\nSelect Line/Polyline in Block :"))	;select the panel/"block" to label
    		(setq errNo (getvar "ERRNO"))
    		(cond ((= errNo 0)	; no ERROR
    			(setq lst  	(apply 'append
    								(list
    									(append
    										(list
    											(+ (* (car (nth 0 (setq entmat (caddr entlst)))) (cadr x))(* (car (nth 1 entmat)) (caddr x))(car (nth 3 entmat))))
    										(list
    										(setq entlst3 (cons (reverse (cdr (reverse (assoc 10 (entget entnew))))) entlst3))))(entget (car entlst)))
    							)))		;end setq
    			"_j" "_mc" "_r" 359.9 y Istring Sstring Pstring "") ;(* 180 (/ (car (vl-sort (mapcar 'angle lst (cdr lst)) '<)) pi))
    			(setq *ptList*(cons y *ptList*))		; add to ptList (for drawing the lines)
    		       ;if panel# is < max, and the str# is < max, then inc str by 1 & set panel#=1
    			  (progn
    				(setq Pnum 1)
    			    	(setq lt *ptList*)
    			    	(prompt "\nDrawing Lines..\n")
    				(setq ptList(reverse *ptList*))		;same way the points were added
    				(setvar "clayer" "E-NEW-POWER-EQUIP")		;change layer
    				(command "._LINE")
    				(apply 'command *ptList*)
    				(command "")
    			    	(setq *fPanel* (car *ptList*))	   ;set FIRST panel in string
    			    	(setq *lPanel* (last *ptList*))	   ;set LAST panel in string
    			    	(DrawCircles *fPanel* *lPanel*)
    			    	(MakeCircleLabels *fPanel* *lPanel* Inum Snum)
    			    	(TrimCircle *tmp1*)
    			    	(TrimCircle *tmp2*)
    			    	(setq *ptList* nil)		; clear list of panels to 'string' together
    			    	(setvar "clayer" "M-GEN-NOTES")		;reset layer
    			  )	  ; end progn
    		       (setvar "ERRNO" 0)   ;set system var to zero
    		       ) ;end cond errNo=0
    		((= errNo 7)	; clicked nothing ERROR
    		 	(prompt "\nSelection Missed. Try Again")
    		 ) ;end cond errNo=7
    		((= errNo 52)	; hit [SPACEBAR]
    		 	(setq *ptList*(reverse *ptList*))		;same way the points were added
    		 	(setvar "clayer" "E-NEW-POWER-EQUIP")		;change layer to PSI "E-NEW-POWER-EUQIP"
      			(command "._LINE")
      			(command "")
    		 	(TrimCircle *tmp1*)
    		 	(TrimCircle *tmp2*)
    		 	(setq *ptList* nil)
    		 ) ;end cond errNo=52
    		(t
    		 ) ;end fallback condition (ELSE)
    	      ) ;end cond
    	(command "._LINE")
    	(command "")
      	(TrimCircle *tmp1*)
      	(TrimCircle *tmp2*)
    	(setq *ptList* nil)
    	(setvar "ERRNO" 0)   ; resset system var to zero
    	(princ)	;clean exit
    )		; END the INCS function
    ; This fxn takes first and last panels as args,
    ;then inserts circles with "inverter.string" text
    (defun DrawCircles (strtC endC)
    	(entmake (list (cons 0 "CIRCLE")(cons 8 "E-NEW-POWER-EQUIP")(cons 10 strtC)'(40 . 12.0)))
      	(setq *tmp1* (entlast))
      	(entmake (list (cons 0 "CIRCLE")(cons 8 "E-NEW-POWER-EQUIP")(cons 10 endC)'(40 . 12.0)))
    	(setq *tmp2* (entlast))
    )  ; END defun DrawCircles
    (defun MakeCircleLabels (strtP endP invNum strNum)  ;(cons 72 10)
    	(entmake (list (cons 0 "TEXT")(cons 8 "GNO")(cons 10 strtP)(cons 1 (strcat (rtos invNum 2 0) "." (rtos strNum 2 0)))'(40 . 8.0))) ;(list (- (cadr strtP) 3)(- (last strtP) 3))
      	(entmake (list (cons 0 "TEXT")(cons 8 "GNO")(cons 10 endP)(cons 1 (strcat (rtos invNum 2 0) "." (rtos strNum 2 0)))'(40 . 8.0))) ;(list (- (cadr endP) 3)(- (last endP) 3))
    )  ; END defun MakeCircleLabels
    ; This fxn trims all things outside CIRCLES
    (defun TrimCircle (entC)
    	(setq old-os (getvar "osmode"))
    	(setvar "osmode" 0)
    	(setq sset (entget entC)) ;(ssget (list (cons 0 "CIRCLE"))))
    	(setq n 0)
    	;(repeat (sslength sset)
    	(setq obj entC) ;(ssname sset 0.0))
    	(setq obj1 (vlax-ename->vla-object obj))
    	(setq cen (vlax-safearray->list (vlax-variant-value (vla-get-center obj1))))
    	(setq rad (vla-get-radius obj1))
    	(setq p 0)
    	(defun DTR (ang)
    		(* PI (/ ang 180.0))
    	);defun DTR
    	(setq ang 0)
    	(repeat 360
    		(setq p1 cen)
    		(setq p2 (polar p1 (DTR ang) rad))
    		(command "trim" obj "" "f" p1 p2 "" "")
    		(setq ang (1+ ang))
    	);repeat
    	;;;	(repeat 360		; this was getting rid of text (dont want to)
    	;;;		(setq p1 cen)
    	;;;		(setq p2 (polar p1 (DTR ang) (- rad (* 0.1 rad))))
    	;;;		(command "erase" "f" p1 p2 "" "")
    	;;;		(setq ang (1+ ang))
    	;;;	);repeat
    	(setq n (1+ n))
    	;);repeat
    	(princ)	 ;clean exit
    )  ; END defun TrimCircle
    Quote Originally Posted by BIG-AL View Post
    ; hard version
    (setq ans "Y")
    (setq ans "N")
  1. Replies: 9
    Last Post: 2015-11-15, 08:35 AM
  2. Deployments need restart after c++?
    By Liamnacuac in forum CAD Management - General
    Last Post: 2014-06-06, 06:08 PM
  3. VB.NET polyline code help
    By mbdesigns2013467754 in forum Dot Net API
    Last Post: 2013-12-19, 09:40 AM
  4. Replies: 1
    Last Post: 2008-11-06, 01:39 PM
  5. Why you may want to restart Revit once in a while
    By Wes Macaulay in forum Revit Architecture - Tips & Tricks
    Last Post: 2003-06-20, 06:39 PM
Tags for this Thread
