Thread: Incremental Attribute values using AutoLisp
    2017-10
    15
    Default Incremental Attribute values using AutoLisp
    Hello,
    I am trying to write a code which will edit attribute in incremental numbering with each click on attribute. The easiest way is to use command "ATTIPEDIT".
    But I failed use ATTIPEDIT in LISP. Pls help to run this code:
    (defun c:DTAG ()
     (princ "\n AUTOMATIC ATTRIBUTE SEQUENTIAL NUMBERING")
     (setq no (getint "\n Enter Starting Number : "))
     (setq pt T)
     (while pt
     (setq notxt (itoa no))
     (setq pt (getpoint (strcat "\n Select Attribute to be changed ( "notxt" ) < exit > : ")))
     (if pt
     (progn
     (command "_.ATTIPEDIT" pt notxt)
     (setq no (+ no 1))
     (princ "\n Routine terminated normally by User")
     (setvar "CMDECHO" ocmd)
     (setq *error* olderr) ;;Restore old error handler
     (princ)
    PFA ACAD file to test. Try putting incremental numbers in place of "0".
    2003-07
    561
    Default Re: Incremental Attribute values using AutoLisp
    Look at reply at Cadtutor.
  1. Replies: 2
    Last Post: 2017-03-11, 06:16 PM
  2. 2013: AutoLISP to Remove Zeros from Attribute Values
    By chris.ortloff676798 in forum AutoCAD General
    Last Post: 2014-07-21, 01:39 PM
  3. AutoLISP function to change DB's values
    By truevis in forum Dynamic Blocks - Technical
    Last Post: 2007-11-19, 05:31 AM
  4. AutoLISP function to get values of existing dynamic block insert
    Last Post: 2007-11-17, 04:34 PM
  5. Add Attribute values together
    By ReachAndre in forum AutoLISP
    Last Post: 2007-10-31, 03:09 PM
Tags for this Thread
