M. Kubitza
I'm just wondering if there's some way to store counter "Y" within the routine vs. sending it to a txt file?
Hi,
You can save them as strings then anytime a user calls the program, the dialog appears then you need to add these strings into the column XXX which is maybe a listbox tile I believe.
Is this what you are after?
If so, then where is the codes to add the strings into your ListBox tile or even popup_list tile.
(setq strings '("a" "b" "c" "d"))
(start_list <ListBox_key> ) (mapcar 'add_list strings) (end_list)
