What graphics cards are tested with ADT 2006:
Have you seem any problem with it.
The following are system requirements taken from Autodesk's website.
Recommended System Requirements
The preceding requirements are recommended for effective use of Autodesk Architectural Desktop 2006 software.
- Intel® Pentium® 4 or AMD-K7™ processor, 1.4 GHz or higher
- Microsoft® Windows® XP (Professional, Home Edition, or Tablet PC Edition, SP2 or later) or Windows 2000 Professional (SP4 or later)
- 1 GB RAM
- 650 MB free hard disk space and 75 MB swap space; 1.3 GB for full installation
- 1024x768 VGA video display
- Microsoft Internet Explorer 6.0 or later
- Modem or other connection to the Internet
- Sound card for multimedia learning
- TCP/IP or IPX support (required only for multiuser or floating license configurations)
Click here for the web page I found this on.
I would have to assume that it would run on the same graphics cards that 2004/5 versions have run on. The 3D stuff is still based on the AutoCAD software platform. This isn't VIZ or MAX, so it won't be a video memory hog unless you are running a 3D view with full shading & edges on. As long as you have the current drivers from the graphic card manufacturer, you should be good to go.
