Thread: auto lisp to vba
    2018-02
    2
    Default auto lisp to vba
    lisp (setq sset (ssget))
    vba Dim sset as AcadSelectionSet
    sset=AutoCAD.Application.ActiveDocument.SelectionSets
    sset.SelectOnScreen
    lisp (setq ctr 0)
    vba Dim ctr as long
    ctr=0
    How convert this lisp to vba??
    ;extract the entity name
    lisp (setq item (ssname sset ctr))
    vba ???????????..........
    2003-07
    561
    Default Re: auto lisp to vba
    this may be helpfull
    vba Dim ctr as Integer
    Set SS = ThisDrawing.SelectionSets.Add("pit1sel")
    SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal
    For Cntr = 0 To SS.Count - 1
    If SS.Item(Cntr).Name = Blkname Then
    2018-02
    2
    Thanks For your reply sir
    how we can use this function in pic.?
    Dim en1 As AcadSection
    en1 = AutoCAD.Application.ActiveDocument.SelectionSets.Name(est).Item(cntr
    2003-07
    561
    You need to explain more what it is your trying to do. i suggested a way to make a selection set with a known name and look at each item in the set. What do you want to do then ?
  1. AUTO LISP
    By M.Jamal Khan in forum AutoLISP
    Last Post: 2020-04-30, 08:47 PM
  2. Auto Lisp
    By MarkLyon in forum CAD Management - General
    Last Post: 2011-02-16, 03:46 PM
  3. Auto-lisp SOS!
    By praveendevdass in forum AutoLISP
    Last Post: 2010-01-14, 07:50 AM
  4. Auto lisp, and TPNAVIGATE
    By ederson_ambrosio in forum AutoLISP
    Last Post: 2009-04-05, 02:10 AM
  5. NEW AUTO LISP
    By rstiles in forum AutoLISP
    Last Post: 2005-11-30, 10:27 PM
