Thread: LISP to insert cogo points
    2018-02
    Default LISP to insert cogo points
    I have several LISP programs used to insert blocks using different formats and I would like to start using c3d points. I have written many LISP functions but have been out of the loop and am very rusty. Also, still learning C3D, I have used LISP programs for years to get along without.
    Attached is my file for reading OPUS files from the NGS and inserting a block. Need to change this to insert color point.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: LISP to insert cogo points
    You can have Civil 3D convert your inserted blocks to points.
    Another solution would have your OPUS.lsp program process the OPUS solution to write a new point file. Then import that point file into a Survey database. The imported points would then be locked to the database until you wish to unlock them.
  1. 2016: cogo points
    By rmk in forum AutoCAD Civil 3D - General
    Last Post: 2017-12-13, 05:30 PM
  2. 2015: Cogo Points
    By tim_newsome in forum AutoCAD Civil 3D - Survey
    Last Post: 2014-11-17, 06:39 PM
  3. Improved Osnap for COGO Points
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2008-11-05, 10:13 PM
  4. exporting cogo points to MX
    By dbutler.144607 in forum AutoCAD General
    Last Post: 2008-05-19, 04:03 PM
  5. Snap to COGO points in LT 2008
    By asehovic in forum AutoCAD LT - General
    Last Post: 2008-04-28, 08:08 PM
Tags for this Thread
