Greetings - Since beam system span tags do not show up in dependent views the work around I use is a detail item with arrows and a dot and a piece of "dumb" text. I'm looking to be able to tag the detail item with info from the beam system schedule (chosen from a list format maybe) that will update in the tag as the info in the schedule updates in response to modeling members or spacing changing. If this is not possible what other workflow would give the same outcome? Thanks in advance.
