Results 1 to 10 of 13
Thread: Help changing a program
    I could stop if I wanted to cadd4la's Avatar
    2001-12
    Newport Beach, CA
    399
    Default Help changing a program
    I'm looking to have some changes to this program I found, so it will not set the layer to nonplot and have the color to be #3 (green). Also, if possible I wish it could change the numbering by one at the end of the layer name (_XXX-changed01, 02, 03, ....) and let you either match the color of the layer you picked or change the layer color by entering the layer color.
    (defun c:MLAYCHA ( / i l n s x )    (if (setq s (ssget "_:L" '((8 . "~*XXX-CHANGED0"))))
            (repeat (setq i (sslength s))
                (setq x (vlax-ename->vla-object (ssname s (setq i (1- i))))
                      l (vla-get-layer x)
                      n (strcat l "_XXX-CHANGED0")
                (if (checkmakelayer l n) (vla-put-layer x n))
        (princ)
    (defun checkmakelayer ( a b )
        (cond
            (   (tblsearch "layer" b))
            (   (setq a (tblobjname "layer" a))
                (setq a (entget a))
                (entmake
                    (subst (cons 2 b) (assoc 2 a)
                        (subst '(62 . 204) (assoc 62 a)
                            (vl-remove-if '(lambda ( x ) (or (= 'ename (type (cdr x))) (= 102 (car x)))) a)
    (vl-load-com) (princ)
    2005-06
    CORDOBA-ARGENTINA
    275
    Default Re: Help changing a program
    Please upload a sample.dwg
    2001-12
    Newport Beach, CA
    399
    Quote Originally Posted by devitg.89838 View Post
    Here is the sample.dwg
    All the code does is have you pick an existing item on the layer then it moves it to a new layer and names that layer the existing name and then adds _XXX-CHANGED0 at the end.
    2005-06
    CORDOBA-ARGENTINA
    275
    test it please , do what you ask
    (defun to-new-layer(/
    ITEM ITEM-LAYER ITEM-OBJ NEWLAYER-NAME
    ;;;All the code does is have you pick an existing item on the layer then it moves it to a new layer
    ;;;and names that layer the existing name and then adds _XXX-CHANGED0 at the end.
    (vl-load-com)
    (princ "\n you pick an existing item")
    (setq item (ssname (ssget "_:S+.")0)) ;;you pick an existing item
    (setq item-layer (cdr ( assoc 8 (entget item)))); item's layer name
    (setq item-obj (VLAX-ENAME->VLA-OBJECT item));item as VL object
    (setq newlayer-name (strcat item-layer "_XXX-CHANGED0")); the new layer name
    (VL-CMDF "_-layer" "m" newlayer-name "");;the new layer
    (VLA-PUT-LAYER item-obj newlayer-name) ;; item at the new layer
    ); end defun to-new-layer
    2001-12
    Newport Beach, CA
    399
    What I can see is you have got the new layer to plot but you have not gotten it to be color 3 or let the user choose a color.
    2005-06
    CORDOBA-ARGENTINA
    275
    It was your last post #3
    2010-06
    962
    Hi,
    Is this what you are after?
    (defun c:mlaycha (/ i l n s x c r d e)
      (if (and (setq s (ssget "_:L" '((8 . "~*XXX-CHANGED0"))))
               (setq r 0 c (acad_colordlg 256))
          (setq x (ssname s (setq i (1- i)))
                e (entget x)
                l (assoc 8 e)
                n (strcat (cdr l) "_XXX-CHANGED" (itoa r))
                r (1+ r)
                d (list '(290 . 0) (cons 62 c))
          (if (tblsearch "LAYER" n)
            (entmod (append (entget (tblobjname "LAYER" n)) d))
            (entmake (append (list '(0 . "LAYER")
                                   '(100 . "AcDbSymbolTableRecord")
                                   '(100 . "AcDbLayerTableRecord")
                                   (cons 2 n)
                                   '(70 . 0)
                             d
          (entmod (subst (cons 8 n) l e))
      (princ)
    2005-06
    CORDOBA-ARGENTINA
    275
    test it , it do what you ask now , the color apply to item not to layer .
    (DEFUN CHANGE-LAYER-NAME-AND-COLOR (/
    ACAD-OBJ
    ADOC
    COLOR
    ITEM
    ITEM-LAYER
    ITEM-OBJ
    LAYER-COLL
    MODEL
    NEWLAYER
    NEWLAYER-NAME
    (VL-LOAD-COM)
    (SETQ ACAD-OBJ (VLAX-GET-ACAD-OBJECT)) ;_ el programa ACAD
    (SETQ ADOC (VLA-GET-ACTIVEDOCUMENT ACAD-OBJ)) ;_ el DWG que esta abierto-
    (SETQ MODEL (VLA-GET-MODELSPACE ADOC))
    (SETQ LAYER-COLL (VLA-GET-LAYERS ADOC))
    (PRINC "\n you pick an existing item")
    (SETQ ITEM (SSNAME (SSGET "_:S+.") 0))
    (SETQ ITEM-LAYER (CDR (ASSOC 8 (ENTGET ITEM)))) ; item's layer name
    (SETQ ITEM-OBJ (VLAX-ENAME->VLA-OBJECT ITEM)) ;item as VL object
    (SETQ NEWLAYER-NAME (STRCAT ITEM-LAYER "_XXX-CHANGED0")) ; the new layer name
    (VL-CMDF "_-layer" "m" NEWLAYER-NAME "")
    ;;the new layer
    (VLA-PUT-LAYER ITEM-OBJ NEWLAYER-NAME)
    (SETQ NEWLAYER (VLA-ITEM LAYER-COLL NEWLAYER-NAME))
    (VLA-PUT-PLOTTABLE NEWLAYER :VLAX-TRUE)
    (SETQ COLOR (ACAD_COLORDLG 3))
    (VLA-PUT-COLOR ITEM-OBJ COLOR)
    2001-12
    Newport Beach, CA
    399
    Quote Originally Posted by Tharwat View Post
    Hi,
                e (entget x)
                l (assoc 8 e)
                r (1+ r)
                                   (cons 2 n)
                                   '(70 . 0)
                             d
      (princ)
    Tharwat,
    Thank you so much, your code lets me choose a new color like I asked, can you also have the new layer be plotable?
    And finally, if possible can you have the code ask for a number from 1-9 to be added to XXX-CHANGED0 i.e. XXX-CHANGED01, XXX-CHANGED02, etc or have it have a number increase by one starting at 01?
    2010-06
    962
    Quote Originally Posted by cadd4la View Post
    Tharwat,
    You are welcome anytime.
    Please try the following and hope it would meet your needs.
    (defun c:crtchglay (/ i l n s x c y r d e)
      ;; Tharwat - Date: 08.Mar.2018	;;
      (if
             (setq r
                    (getstring
                      "\nSpeficy a number from [1-9] or [01-09] <enter to exit> :"
             (or (numberp (read r))
                 (progn (princ "\nInvalid input!. Please try again.") nil)
             (setq y (and (= (strlen r) 2) (wcmatch r "0*"))
                 e (entget x)
                 l (assoc 8 e)
                 n (strcat (cdr l) "_XXX-CHANGED" r)
                 d (list '(290 . 1) (cons 62 c))
                 r (1+ (atoi r))
                 r (if (and y (< r 10))
                     (strcat "0" (itoa r))
                     (itoa r)
                                    (cons 2 n)
                                    '(70 . 0)
                              d
      (princ)
  1. 2014: Changing an objects Level without changing it's relative place in space?
    By evan549822 in forum Revit MEP - General
    Last Post: 2014-08-19, 02:05 PM
  2. Writing a Short program from Large Program
    By avinash00002002 in forum VBA/COM Interop
    Last Post: 2006-07-13, 01:26 AM
  3. Changing font without changing Text Style.
    By zoomharis in forum AutoCAD General
    Last Post: 2006-03-22, 05:51 PM
Tags for this Thread
