Results 1 to 7 of 7
Thread: Get list to visibility states of dynamic block
    2009-04
    Houston, TX
    204
    Default Get list to visibility states of dynamic block
    Is it possible to get a list of all block visibility states, not just the current state?
    I have a lisp routine to update titleblock info and it would be nice if each time someone new gets hired, or leaves, only updating the dynamic block would need to be done... and the routine would just grab the list of visibility states and "update itself".
    Turlock, CA
    6,420
    Default Re: Get list to visibility states of dynamic block
    Are you working with lisp or vba?
    C:> ED WORKING....
    LinkedIn
    2009-04
    Houston, TX
    204
    My mistake, working in lisp. Browsing around and forgot which forum I was in.
    2015-10
    Central New Jersey
    439
    Wouldn't this just be a matter of redefining the block via something like design center or a tool palette?
    2010-06
    962
    Hi,
    Please try this:
    (if (and (setq blk (car (entsel "\nSelect Dynamic block with Visibility State :")))
             (= (vla-get-isdynamicblock (setq blk (vlax-ename->vla-object blk))) :vlax-true)
      (progn
        (setq props (vlax-invoke blk 'getdynamicblockproperties))
        (foreach prop (vlax-get (car props) 'allowedvalues)
          (print prop)
    ) (vl-load-com)
    2009-04
    Houston, TX
    204
    Quote Originally Posted by Tharwat View Post
    Hi,
    Please try this:
      (progn
          (print prop)
    ) (vl-load-com)
    This works perfectly yes.
    2010-06
    962
    Quote Originally Posted by M. Kubitza View Post
    Good for you.
  1. 2016: Dynamic block that shows/hides certain visibility states
    By kazakhkaster743054 in forum Dynamic Blocks - Technical
    Last Post: 2017-02-17, 12:14 PM
  2. LSP & Dynamic Block Visibility States
    By ReachAndre in forum AutoLISP
    Last Post: 2007-11-20, 09:32 AM
  3. Getting Visibility States to work in a Single door Dynamic Block
    By KGC in forum Dynamic Blocks - Technical
    Last Post: 2007-01-02, 03:40 PM
  4. Visibility States list not showing
    By Jack Cheong in forum Dynamic Blocks - Technical
    Last Post: 2006-08-11, 04:36 AM
  5. Is there a way to see all Visibility states within a Dynamic Block
    By KansasCAD in forum Dynamic Blocks - Technical
    Last Post: 2006-04-17, 06:51 PM
