Results 1 to 8 of 8
Thread: AutoCAD Warning on opening
    100 Club Lemons's Avatar
    2001-06
    Beautiful Charleston, SC
    176
    Default AutoCAD Warning on opening
    I get this warning every time I open AutoCAD (see attached). It's bogus. I don't remember the fix but know that there is an easy one.
    Any help is greatly appreciated, thanks
    It's a lovely day
    in the upper right corner
    3,109
    Default Re: AutoCAD Warning on opening
    Well I've seen something like this before, and looking at your screen shot, I bet there's a "Add-A-Plot Style Table.lnk" and a "Add-A-Plotter-Wizard.lnk" (shortcuts) at "y:\autocad configuration files\pen tables\.." directory.
    And they shouldn't be there, the default is something like: C:\Users\<you>\AppData\Roaming\Autodesk\AutoCAD 2017\R21.0\enu\Plotters
    I don't know what causes those shortcuts to be created in the wrong place but it happens now and then at my work.
    I would verify you have them at the default locations and remove them from the "y:\" drive in your screen shot, that should fix it.
    HTH
    Ted
    Windows 7 Professional
    AutoCAD 2017 - REVIT 2017 - Inventor Professional 2015 (when I can)
    9,532
    Go find and delete that shortcut and any others (if file extensions are visible, these are .LNK files)
    2001-06
    176
    Thanks, guys! I do not have the authority to delete the offending files, so I took them out of my search path. Problem solved
    HAHAHAHAHHHHH, until I went to plot!
    Of course the print/plot parameters/tools are in the network location, not my local, so I added the offending paths back in and will put up with the warning message. It's not my call or right to delete the shortcuts.
    It's a lovely day
    3,109
    Quote Originally Posted by Lemons View Post
    LOL well at least you know the issue.
    Have your IT dude or cad manager (or whoever had the rights) delete them..
    Ted
    2,092
    That usually happens here when someone edits the plot style or PC3 from inside AutoCAD with rights to that folder.
    If you are going to fly by the seat of your pants, expect friction burns.
    Some say beauty is in the eye of the Beholder... perhaps so, but I've only seen the disintegration beam.
    Everyone else being wrong is not the same thing as being right.
    2001-06
    176
    Thanks for the suggestion. I'm only 3 weeks in this position so I'm going to wait a bit before I take any action. I'm gaining the favor of the principals and want that favor cemented before I rock the boat, even a little.
    Hmm, interesting that dgorsman had this to say: That usually happens here when someone edits the plot style or PC3 from inside AutoCAD with rights to that folder.
    The shortcuts are bad links, so they really should be deleted or fixed. Maybe I'll get one of my engineers to delete them.
    It's a lovely day
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,401
    The .lnk file is typically pointing to a path which you do not have access to. This is usually when the plotters and plot styles folders are copied to a network path from a previous (or different) version than is currently being used.
  1. 2017: AutoCAD 2017 SP1 warning
    By rkmcswain in forum AutoCAD General
    Last Post: 2016-07-25, 12:34 PM
  2. 2012: AutoCAD Warning at Startup
    By heinsite in forum AutoCAD General
    Last Post: 2012-12-26, 08:01 PM
  3. Autocad Map Warning
    By 09silverado in forum Geospatial - General
    Last Post: 2009-08-25, 09:14 PM
  4. AutoCAD Warning message
    By jasontirone in forum ACA General
    Last Post: 2005-06-24, 04:45 PM
  5. AutoCAD Warning
    By ed.kinsel in forum AutoCAD Plotting
    Last Post: 2004-12-29, 04:51 PM
