Thread: Change transparency of a layer on Autocad using vba
    2018-03
    4
    Default Change transparency of a layer on Autocad using vba
    Hello,
    I am trying to change the transparency percentage of a layer using VBA.
    tHIS IS my code:
    Sub Access_Autocad() 'nom de ma procédure
    Dim AutoCAD As Object 'Autocad est la variable ici
    Set AutoCAD = CreateObject("Autocad.Application") 'ouvre AutoCad
    AutoCAD.Visible = True
    Set AutoCAD = AutoCAD.Documents.Open("P:\Plannif_VBA_AutoCAD\PLA_TEN_C18_406_RONDES.dwg") 'ouvre fichier ronde
    Dim layer_ronde As AcadLayer
    Set layer_ronde = AutoCAD.Layers.Add("99103") 'attribuer à la ronde le nom du calque correspondant
    layer_ronde.Color = acRed 'cahanger la couleur du calque
    Dim layer_ronde1 As AcadLayer
    Set layer_ronde1 = AutoCAD.Layers.Add("99103")
    layer_ronde1.Color = 12
    Dim layer_ronde2 As AcadLayer
    Set layer_ronde2 = AutoCAD.Layers.Add("99105")
    layer_ronde2.Color = 16
    Dim layer_ronde3 As AcadLayer
    Set layer_ronde3 = AutoCAD.Layers.Add("99106")
    layer_ronde3.Color = 5
    I thought abput using layer_ronde3.Transparency and then equal that to the percentage of transparency needed.
    However....Transparency only works for Image. At least, that what i understood.
    I think there is a method to convert it but i been looking and can't find it.
    cOULD SOMEONE HELP ME?
    I began Learning vba 2 days ago so i have a lot to learn.
    Turlock, CA
    6,419
    Default Re: Change transparency of a layer on Autocad using vba
    Sorry, its not available to the vba api. You need to use .net. See this help topic. To use vba, you would need to work with the layer command using the ThisDrawing.SendCommand method.
    Here is a thread about using lisp to access the AcCmTransparency table directly to get the Transparency property of a layer. I haven't examined the possibility to translate it to vba.
    C:> ED WORKING....
    LinkedIn
    2011-12
    You can get it through XData, but not set it.
    http://adndevblog.typepad.com/autoca...sing-lisp.html
  1. Replies: 8
    Last Post: 2014-11-07, 12:11 PM
  2. 2012: Layer transparency
    By depth3d in forum AutoCAD General
    Last Post: 2011-10-03, 11:14 AM
  3. Presenter materials DO NOT change transparency in Animator
    By WT-09 in forum NavisWorks - General
    Last Post: 2010-10-28, 07:27 PM
  4. Change transparency behaviour back to as it was in Revit 2008
    Last Post: 2008-07-22, 02:07 PM
  5. Replies: 7
    Last Post: 2006-05-05, 01:41 AM
Tags for this Thread
