Thread: Keynotes
    2014-07
    31
    Default Keynotes
    Can I have notes 1-46 and 1-94 (different notes) in the same text file so that I can have them on different sheets?
    2002-09
    Madison, WI
    5,687
    Default Re: Keynotes
    If you have a keynote data base you can edit them anyway you'd like.
    If you want them to be consistent (same number on every sheets) do keynotes by project (number) and not by sheet (sequential))
    2014-07
    31
    I have noticed that some firms do key notes different ways. Some use schedules and families. They have a text file that is loaded into an RFA file. There is a schedule for every sheet. The text file is very special and delineated with commas. Looks like a mess. The other more standard way is using the legend keynote system with standard text delineated with tabs. Not sure the advantages or disadvantages of each but I am guessing that the 1st one was used before autodesk bought revit. The ribbon was different and I am not sure if they even had the "keynote" legend in 2000. I was using it but cant remember. I do recall they had different ribbon titles like BASIC and DRAFTING.
    2002-09
    Madison, WI
    5,687
    The other option is using a note block. Personally I'm not a fan of this method.
    There's a bunch of tools out there that will assist with your keynoting issues.
    There's a product called keynote manager that works really slick. It's worth the price. It's cheap in my mind.
    It solves the issues with needing to edit the delineated text file.
  1. Reference Keynotes and sheet keynotes together on sheet
    Last Post: 2017-10-25, 11:55 PM
  2. User Defined Keynotes, Keynote Legend, Keynotes by Sheet (QUESTIONS)
    By prestonljones438185 in forum Revit - Platform
    Last Post: 2013-12-13, 12:30 AM
  3. Revit - Reference Keynotes & Sheet Keynotes on Same Sheet
    By jjsimon in forum Revit - Platform
    Last Post: 2010-06-09, 10:50 PM
  4. Keynotes
    By johnf.77896 in forum Revit Architecture - General
    Last Post: 2006-12-06, 12:09 AM
  5. Keynotes V9
    By sjsl in forum Revit Architecture - General
    Last Post: 2006-05-01, 08:29 PM
