Thread: Typing OPEN issues the OPENSHEETSET command
    2011-09
    308
    Default Typing OPEN issues the OPENSHEETSET command
    Hi folks, hope this is the correct forum to post this.
    For some reason, when I type OPEN and press ENTER, the command the is issued is OPENSHEETSET. Of course this only allows me to open .dst files, which is not what I want.
    If I redefine OPEN it works fine until I restart AutoCAD.
    Nothing in acad.lsp or acaddoc.lsp that is redefining OPEN.
    Also, if I deselect everything in Input Search Options... works fine.
    Baffled, any help is appreciated.
    JP
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: Typing OPEN issues the OPENSHEETSET command
    The default is whatever starts with OPEN that you've used the most. I don't use OPENSHEETSET to often so OPEN is my default, you need to pick from the list after typing OPE. Use it more often and it will become your default.
    2011-09
    308
    Thanks Tom,
    That's the thing, I never use OPENSHEETSET...
    And if I type OPEN and just wait, the OPEN command is not in the list that shows up.
    2011-09
    308
    I just did a reinstall. Upon launch I see this in the text window:
    Loading AcadOdma ARX application ....OK!
    _undefine _NEW
    _undefine _OPEN
    _undefine _QSAVE
    _undefine _SAVE
    _undefine _SAVEAS
    _undefine _+SAVEAS
    Pretty sure AcadOdma ARX is Projectwise...
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Does CTRL + O start the Open dialog?
  1. 2014: inserting detail items by typing name into command line
    By fmplatt530 in forum AutoCAD General
    Last Post: 2015-09-14, 11:21 PM
  2. Replies: 6
    Last Post: 2014-07-11, 10:57 AM
  3. Command: _-OPENSHEETSET
    By drewj in forum AutoCAD Sheet Set Manager
    Last Post: 2011-09-24, 10:04 AM
  4. Open drawing issues
    By mclark.235191 in forum AMEP General
    Last Post: 2010-05-05, 11:48 PM
  5. Memory issues with Audit during open
    By ErichB in forum Revit Architecture - Tips & Tricks
    Last Post: 2009-07-29, 11:50 PM
