I am trying to create an opening in an exterior wall that will bevel back toward the window. Seeing as Revit only creates square edges on the wall ends, how could this be accomplished? (See image attached)
Welcome to the forums. The easiest way to accomplish this is using a ‘void blend’ to cut the wall. Depending on the number of openings you have on the Model and your experience level with Revit you can make the void part of your window family, do it as a separate loadable family or create it as an in-place family.
