Results 1 to 1 of 1
Thread: Field expression in attribute shows ####
    2018-03
    Default Field expression in attribute shows ####
    I am trying to define x and y lengths (as field) based on 4 points. The lengths are displayed in block attributes. When i create block first time it works well. But when i insert
    blockreference, i does not work. it shows XXXX. pls see screenshot attached. The attribute is only locked. other property are as it is. I have serched for so long.
    But could not find proper solution.
    This is field i want to use in attribute.
    DistXunit = "%<\AcExpr (rxof((" & CStr(FourthPtX) & " - " & CStr(FirstPtX) & ")+(" & CStr(ThirdPtX) & " - " & CStr(SecondPtX) & "))/2) \f ""%lu6"">%"
    Here i define a block with "Xdist" attribute and insert block. I can see field here.
    '' Add Xdist attribute
    Dim AttrX As AcadAttribute
    Dim InsX(0 To 2) As Double
    Set AttrX = BlockLable.AddAttribute(TextSz, acAttributeModeVerify, "X distance", InsX, "XDIST", DistXunit)
    '' Insert the block, creating a block reference and an attribute reference
    Dim blockRefLable As AcadBlockReference
    Set blockRefLable = ThisDrawing.ModelSpace.InsertBlock(InsPtFinal, "NISH-ALABLE", 1#, 1#, 1#, Rangle)
    Here i insert the same block and change "Xdist" attribute. And i see field ####.
    '' Get the old attributes
    Dim VarAttributes As Variant
    VarAttributes = TempRef.GetAttributes
    ''change attribute value
    VarAttributes(2).TextString = DistXunit
    Any help is appreciated. Thanx.
  1. 2015: How to customize field expression
    By Klaus.Hellweger732121 in forum AutoCAD Mechanical - General
    Last Post: 2018-07-06, 08:17 AM
  2. read field expression of an attribute
    By alberto.boffi695984 in forum AutoLISP
    Last Post: 2011-06-02, 07:29 AM
  3. Customizing field expression
    By amarkovi in forum Dynamic Blocks - Technical
    Last Post: 2009-03-31, 06:00 PM
  4. Field expression change
    By csiress in forum AutoCAD Fields
    Last Post: 2007-11-20, 06:37 PM
  5. Replies: 1
    Last Post: 2007-06-06, 05:50 PM
