Hello all,
I'm not sure if this is the right forum or not, but here goes:
When creating 4 elevations of my building, I use the annotation tool Exterior (Elevation) denoted by four elevation markers pointing to a center point. So, when I go to insert the AEC 2D Elevations that are linked to my model, all of these white boxes appear from what I assume are prior elevations that have been deleted. They do not show up unless I am creating new elevations and I can't find a layer to turn on or off to show them so I can get rid of them. Since they are still there, how do you purge those out of the drawing or is that even possible? Any help would be greatly appreciated, and if I'm not in the correct forum, if you could direct me to the appropriate one, that would be great. I don't visit the forums a lot, but every now and then, I run into an issue and I usually find an answer. This time, I have not been so lucky. Thanks for your help!
