To start with, my task was to find out the volume of water on a sloped roof at 4" and 6" above the low point.
To do this, I decided to place a space at roof level and adjust the extents to 4" and 6" above the low point. To calculate the volume, this process worked out well, however my engineer would also like a plan view showing the extents of the water in plan view. As you can see in the attachments the color extents are not matching the space extents in plan view, but in section view the color extents look just fine. I've created a little dummy project that is having the same issue and is attached.
I have a feeling this has to do with my view range, there are some funky values as to see the color fill you need to cut through the space.
All help is greatly appreciated!
