Hi all
I not been able to resolve a problem that appears when ever I'm trying to import a family that uses shared parameters. Error message below appears;
Can't edit the element until "my user name" resaves the element to central and relinquishes it and you Reload Latest.
Shared Parameters : : New Shared Parameters : id 46017
I have tried select elements by ID and a dialogue box appears with the message "The following Element IDs are invalid and won't be used: 0".
I believe to problem to be generated via a setting within the workset i'm using, under the Project Standards we have a field named Shared Parameters and I am listed as "borrowers" for this field.
How do I uncheck this Borrowers field?
Thank you in advance
