Thread: Change Associated Level on a view?
    in the upper right corner
    3,508
    Arrow Change Associated Level on a view?
    I can't find this answer anywhere, and help implies this is "not editable", I'm hoping it's wrong or there's a work around.
    I have a view called "Mech Roof Framing" which about 6'-0" above the "High Roof" level.
    If I recall, that is how this view was created, at one time it was a lot closer to the roof and so a new level wasn't' created, just the framing was offset from the roof framing in a copied view.
    Now, the framing is further away from the roof and a new level has been created, and I want to "associate" the view with the new level.
    I can "put" the framing on the new level but things like T.O.S. elevation tags still sees it associated with the roof level.
    This is not associated with a view template.
    Does anyone know if this can be done and how to do it?
    Any help will be appreciated, thanks.
    Digital Delivery Director Brian Myers's Avatar
    2003-02
    Stillwater, Oklahoma
    1,819
    Default Re: Change Associated Level on a view?
    While there are workarounds (cut /paste content; view templates for view settings, etc) the only way to accomplish this is by creating a new view.
    3,508
    Thanks Brian, I was afraid that was going to be the answer.
  1. Change Associated Level of a view after creating it
    Last Post: 2013-10-29, 05:10 PM
  2. View Stairs on Upper Level Similar to lower level
    Last Post: 2013-02-12, 12:32 PM
  3. can you change the associated level of a view?
    By JAC.95598 in forum Revit MEP - General
    Last Post: 2010-11-12, 06:22 PM
  4. Change the view assinged to a level
    By cerezor in forum Revit Architecture - General
    Last Post: 2010-10-05, 06:03 AM
  5. Change the Detail Level of Subcategories in the view templates
    By JH75 in forum Revit Structure - Wish List
    Last Post: 2009-03-24, 09:33 AM
