Thread: Update Custom Ribbon ICONS in AutoCAD
    2006-09
    35
    Default Update Custom Ribbon ICONS in AutoCAD
    If I want to update our ICONS for our company Ribbon in AutoCAD, it seems I have to create a copy and/or rename it, then load the newly updated image with a different name. Isn't there some way to force the icon to update without creating a updated copy with a different name?
    I thought I could delete the MNR and force it to recompile, but I've not found this to work as I thought it should.
    Tallahassee, FL USA
    3,667
    Default Re: Update Custom Ribbon ICONS in AutoCAD
    I've seen that before, changing icons wasn't enough to force an update. Changing an item's position in the Ribbon should do it. You can change it back afterwards.
  1. AutoCAD 2012 ribbon has icons but no text
    By michael.12445 in forum AutoCAD General
    Last Post: 2012-03-06, 04:24 PM
  2. 2012: C# - Ribbon Icons
    By Bryan Thatcher in forum Revit - API
    Last Post: 2011-08-29, 06:19 AM
  3. Ribbon Icons
    By bshank.140587 in forum ACA General
    Last Post: 2010-03-23, 11:33 AM
  4. Transparency with custom AutoCAD 2009 icons
    By swells132024 in forum AutoCAD CUI Menus
    Last Post: 2009-09-28, 03:01 PM
  5. AutoCAD 2009 Update 1 and Ribbon Modifications
    By RobertB in forum AutoCAD CUI Menus
    Last Post: 2008-07-28, 07:02 PM
