Thread: Is there a way to calculate total distance or length when using conduits in Revit?
    2018-03
    4
    Default Is there a way to calculate total distance or length when using conduits in Revit?
    When drawing out routes and assemblies in Revit to translate to the field, I usually get question like whats the total length of the feeder. I'm not sure how I could use Revit to come up with the answer. I usually have the track each feeder back per sections add them up then count up the elbows add those in and round them up. Is there a better way of doing this?
    Also it would be nice if cable trays had this feature as well.
    2002-09
    Madison, WI
    5,688
    Default Re: Is there a way to calculate total distance or length when using conduits in Revit?
    I haven't played around with them much, but I would suspect that you could set up each run with a unique identifier. Maybe new parameter called Run Number (Or use the Service Type, but I'm not sure what that's used for) Then schedule them and group them by run number - Calculate the length and have Revit total it. I'm guessing you could do a similar thing for Fittings. Apply the same parameter to them and you can get a count.
    It also looks like there's an option to do a schedule for Conduit runs. That might be easier.
    I don't do electrical work, but that sounds like the solution your might be looking for.
  1. Replies: 9
    Last Post: 2015-05-03, 07:12 PM
  2. 2012: Calculate travel distance to exit
    By MikeJarosz in forum Revit Architecture - General
    Last Post: 2012-10-11, 02:52 PM
  3. AutoLISP routine to calculate the total weight of steel
    By robert.1.hall72202 in forum AutoLISP
    Last Post: 2012-07-19, 05:18 AM
  4. Calculate distance - automatic
    By rodrigoabb in forum AutoCAD Map 3D - General
    Last Post: 2009-08-21, 01:55 PM
  5. calculate the total length of a group of polylines
    By eebryant in forum AutoCAD Map 3D - General
    Last Post: 2008-10-20, 06:36 PM
