Thread: Flow direction is changing
    2005-03
    Hyderabad, INDIA
    26
    Question Flow direction is changing
    Pipes flow directions are changing in AutoCAD Land desktop MAPCLEAN command. Suppose If I dissolve the two pipes which are in the same direction some times the result pipe direction is opposite to the previous direction. Why this is happening?
    Kotesh.
    2001-03
    13,499
    Default Re: Flow direction is changing
    Hi Kotesh
    Please note I've *moved* this thread from the AutoLISP Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    Civil Engineering Moderator MHultgren's Avatar
    Clyde, NC - USA
    1,381
    Are you Simplifying the Geometry when run the command? Snapping clustered nodes? What are your settings in the pipe run editor? D\s to U\s or vica versa? Were your pipes defined using these settings?
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
    2005-03
    Hyderabad, INDIA
    26
    Hi,
    I am very glad with your response. ThanQ very much..
    Actually the procedure I am following is...
    1. Open a new drawing in AutoCAD Landesktop 2005
    2. Draw a simple LWPOLYLINE with command PLINE with more than 2 vertices say 'A'.
    3. Draw another LWPOLYLINE from the end point(Be sure U must draw from the from the end point only) of 'A' with more than 2 vertices say 'B'.
    4. Go to menu MAP->Tools->Drawing cleanup.
    5. Select objects 'A' and 'B' in the sequence.
    6. In the cleanup actions add 'Dissolve Pseudo Nodes' only.
    7. Press finish.
    8. See the resultant LWPOLYLINE flow direction using PEDIT command.
    Regards,
    Kotesh.
    Clyde, NC - USA
    1,381
    When you define the pipe run, you should see a yellow triangle at each vertice showing you which way the slope i going, Pipes will prompt you if you want to change direction, simply say yes at the prompt to reverse the flow. Or if you already have the pipe run defined, you can go to Conceptual Plan - Reverse Flow to change it after the fact.
    Mark Hultgren
    Just a Lurker
    Blog
    Socializing??
  1. Air Terminal flow direction
    By dcorino in forum Revit MEP - General
    Last Post: 2011-07-13, 07:09 PM
  2. Wye Combination w/8th Blend flow direction problem
    By jamstearns in forum Revit MEP - General
    Last Post: 2011-02-28, 12:50 PM
  3. Flow direction
    By avn in forum AutoCAD Civil 3D - Pipes
    Last Post: 2008-02-21, 02:44 PM
  4. Civil 3D 2007 - Change flow direction of pipes
    By t-square in forum AutoCAD Civil 3D - Pipes
    Last Post: 2007-05-25, 01:46 PM
  5. Flow DirectioN Mismatch
    By mjdanowski in forum Revit MEP - General
    Last Post: 2007-04-05, 02:31 AM
