Results 1 to 8 of 8
Thread: Inserting Dynamic Blocks along the points of Polyline using LISP
    2017-10
    15
    Exclamation Inserting Dynamic Blocks along the points of Polyline using LISP
    Hi, I want a LISP routine which can insert blocks along the polyline.
    I have two dynamic blocks. They are 'Straight Duct' and 'Elbow90'. Consider I draw a polyline with three XY coordinates i.e. (1,1) , (1,2) and (2,2) and insert rectangular block with desired 'Width'. Here are list of things I want from LISP program:
    1. I want 'Straight Duct' to be inserted at mid-points of '(1,1) & (1,2)' and '(1,2) & (2,2)'.
    2. Also, those inserted blocks should be rotated with an angle made by those points with horizontal so that 'Straight Duct' remains along the line. Example, Angle made by line joining points '(1,1) & (1,2)' with horizontal is 90 Deg. Hence, Dynamic Block should be rotated by 90 degree about midpoint.
    3. Move the grip of 'Straight Duct' (which facing to open end of polyline) to the open end of polyline. Move other grip of 'Straight Duct' to the length of (150+ Width/2) mm less than the intersection point.
    4. Insert 'Elbow90' at the point with polar angle 45 Degree to point of intersection and polar radius (150 + Width/2) mm. Also, the grip of elbow should be moved so that width of 'Elbow90' should be as same as that of 'Straight Duct'.
    Pls refer the attached file for understanding the problem.
    Can anyone help me out?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Inserting Dynamic Blocks along the points of Polyline using LISP
    Have you any code to share with others? Other members may have code they may be willing to share to help you get started.
    Do you need somewhere to start? You might try searching the forums. I found this which may meet some of your request.
    Or are you looking for a ready made routine? For me, your request does not fit my field of work. I can't help you.
    2015-09
    5
    Quote Originally Posted by sbmunde View Post
    Here you can find somthing useful
    https://autolispprograms.wordpress.c...c-application/
    2017-10
    15
    Unhappy Re: Inserting Dynamic Blocks along the points of Polyline using LISP
    Here is the code I am working on:
    This code insert "Straight Duct" block at required points and with required rotation.
    But I am not able to insert "Elbow90" (Don't Know Why?). But I am working on it.
    I want to know if I can move grips of that dynamic blocks to required points.
    Can you help me?
    (vl-load-com); if needed
    (defun C:PtoDB (/ plent plobj coords num pt)
      (setq
        plent (car (entsel "\nSelect Polyline: "))
        plobj (vlax-ename->vla-object plent)
        coords (vlax-get plobj 'Coordinates); un-differentiated list of X Y [& Z if applicable] coordinate values
      ); setq
      (setq num (if (= (cdr (assoc 0 (entget plent))) "LWPOLYLINE") 2 3))
        ; LW Polylines have only X & Y; "heavy" 2D & 3D have X Y & Z
      (repeat (/ (length coords) num)
        (repeat num ; number of coordinates to separate into a point list
          (setq
            pt (append pt (list (car coords)))
            coords (cdr coords)
        ); repeat
      ); repeat
      (setq pt (reverse pt)); list of coordinates divided up into point lists
      (setq width (getint "Enter the width of duct:"))
      (setq p1 (list (nth 1 pt) (nth 0 pt) 0))
      (setq p2 (list (nth 3 pt) (nth 2 pt) 0))
      (setq p3 (list (nth 5 pt) (nth 4 pt) 0))
      (setq ang1 (angtos (angle p1 p2)))
      (setq ang2 (angtos (angle p2 p3)))
      (setq diff (+ 150 (/ width 2)))
      ;(princ diff)
      (cond ((and (and (> (cadr p2) (cadr p1)) (= (cadr p2) (cadr p3))) (and (= (car p2) (car p1)) (> (car p2) (car p3))))
    	(setq ang3 (itoa 0))
    	(setq p4 (list (- (car p2) diff) (- (cadr p2) diff) 0))
      	((and (and (> (cadr p2) (cadr p1)) (= (cadr p2) (cadr p3))) (and (= (car p2) (car p1)) (< (car p2) (car p3))))
    	(setq ang3 (itoa 90))
    	(setq p4 (list (+ (car p2) diff) (- (cadr p2) diff) 0))
    	((and (and (= (cadr p2) (cadr p1)) (< (cadr p2) (cadr p3))) (and (< (car p2) (car p1)) (= (car p2) (car p3))))
    	(setq ang3 (itoa 180))
    	(setq p4 (list (+ (car p2) diff) (+ (cadr p2) diff) 0))
    	((and (and (= (cadr p2) (cadr p1)) (< (cadr p2) (cadr p3))) (and (> (car p2) (car p1)) (= (car p2) (car p3))))
    	(setq ang3 (itoa 270))
    	(setq p4 (list (- (car p2) diff) (+ (cadr p2) diff) 0))
      (command "_Insert" "Straight Duct" "_mtp" p1 p2 1 "" ang1)
      (command "_Insert" "Straight Duct" "_mtp" p2 p3 1 "" ang2)
      ;(command "_line" p2 p4 "")
      (command "_Insert" "Elbow90" p4 1 1 ang3)
    ); defun
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    2017-10
    15
    Thank you Responses. I have arrived near to the end of my program. The program can insert blocks with changing parameters & attributes to required value. But, the block "Elbow" is not inserted at required point. I couldn't find the reason behind that. Can anyone please help me to find the error. The block "Ebow90" should be inserted at point 'P4'.
    Pls find attached files to understand the problem.
    2002-01
    jUSt Here (a lot)
    9,106
    After you execute the routine, is P4 set to the expected coordinates? Are you using running osnaps? If one or both of these are true, you might place a "non" osnap declaration prior to providing the P4 coordinate to the Insert command.
    2017-10
    15
    Thanx Opie. I forget to turn off the Osnap
    I have added below lines:
      (setq os (getvar 'osmode))
      (setvar 'osmode 0)
      ;CODE HERE
      (setvar 'osmode os)
    Now, it runs fine.
    Thank you all.
  1. Inserting blocks in table cells using LISP
    By costas.vassiliou in forum AutoLISP
    Last Post: 2018-11-29, 08:51 PM
  2. Inserting dynamic blocks into table?
    By jzampardi in forum Dynamic Blocks - Technical
    Last Post: 2010-05-14, 06:42 PM
  3. Polyline Thickness in Dynamic Blocks
    By CADdancer in forum Dynamic Blocks - Technical
    Last Post: 2009-10-28, 05:18 PM
  4. Replies: 4
    Last Post: 2007-04-29, 11:51 AM
  5. Lisp code when inserting blocks from tool palettes
    Last Post: 2006-06-02, 12:49 PM
Tags for this Thread
