Results 1 to 6 of 6
Thread: Line and Curve Tag Labels
    2004-11
    2
    Default Line and Curve Tag Labels
    OK, I know I am rehashing a old topic that will never be resolved but, here is a different twist (I think).
    Is there a way to put a place holder in a line/curve table to skip a number or series of numbers?
    The only way I can think of is making a dummy line(s) off in space and labeling them the number sequence you want a place holder for then, in paper space applying a mtext with background mask and adding your custom text. I have done this before (see attached) but, looking for a more efficient or elegant way of doing this.
    Manual renumbering the remaining 102 lines is not an option for cost/time/human error purposes and, manager want all lines accounted for (no break in sequence).
    ** explanation of line work in table **
    Its a simple array for text spacing on a no plot layer. This should be self explanatory but, someone will ask.
    Thanks for everyone's time.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Default Re: Line and Curve Tag Labels
    This is Civil 3D. They don't make these things easy. Your (time consuming) method is possibly the only method to complete your task.
    2004-06
    Slidell, Louisiana
    972
    if you explode the table twice, it converts everything to lines and mtext, so you could delete the bearing and distance.
    downside is they're not dynamic anymore.
    2004-06
    Slidell, Louisiana
    972
    Quote Originally Posted by deleted
    removed
    the link isn't there.
    Cairo - no, not Illinois
    5,069
    don't worry about the missing link. he's a first time poster, probably a spammer -- since there nothing pertinent to the conversation in the bland reply. that could be a reply to 99.9 percent of posts on this forum. and it's reported
    2001-12
    St. Louis
    5,407
    New posters can share links, but, they're hidden until it is determined that they are not spam.
    Thanks for the report, CADtag, the link was clearly spam and the banhammer was duly dropped. Appreciate those who help keep the forums full of legit content!
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. Tag options for General Line\Curve labels
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2016-10-27, 03:58 AM
  2. Rotate Line and Curve Labels
    Last Post: 2015-10-24, 04:37 PM
  3. 2014: Line and Curve labels do not print right
    By mhildenbrand in forum AutoCAD Civil 3D - General
    Last Post: 2013-11-06, 03:03 AM
  4. Filter line/curve table creation by labels already in tag mode
    Last Post: 2009-10-06, 03:44 PM
  5. Vert. Curve Labels-Dim line?
    By randyspear in forum AutoCAD Civil 3D - Profiles
    Last Post: 2008-06-18, 06:30 PM
Tags for this Thread
