Thread: Surface breaklines with 0 or 1 vertices?
    Earth
    9,805
    Question Surface breaklines with 0 or 1 vertices?
    User has a surface that 'disappears" upon drawing open.
    Turns out our startup code purges zero-length entities, and all but a couple of the break lines in this surface have either 0 or 1 vertex.
    So when the zero-length entities are purged, the surface has no more definition and disappears.
    Undoing that purge restores an otherwise normal looking surface.
    Not sure how it's possible for a break line to have 0 or 1 vertices. Anyone else ever seen this?
    R.K. McSwain | CAD Panacea |
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Surface breaklines with 0 or 1 vertices?
    Nope. I've never experienced it.
    Could it possibly be counting only interior vertices and not also the end points?
    Earth
    9,805
    No. If you make a single polyline or breakline with two points (start > end), and add it to a surface, it shows up as 2 vertices.
  1. Replies: 1
    Last Post: 2017-04-18, 12:57 PM
  2. Replies: 0
    Last Post: 2012-10-24, 04:55 PM
  3. Replies: 0
    Last Post: 2012-10-24, 04:32 PM
  4. Replies: 1
    Last Post: 2012-01-05, 09:13 PM
Tags for this Thread
