Results 1 to 7 of 7
Thread: Cut 3d Box Culvert From EG Surface
    2018-04
    Default Cut 3d Box Culvert From EG Surface
    Hello all,
    I'm trying to create a surface that reflects the existence of a 6' x 6' box culvert running underneath a dirt road. This culvert is going to be ripped out and replaced.
    For our design team, I'd like to be able to create a 3d object reflecting the box culvert that I can trim from the surface, so that our materials calculations will be correct.
    So far I have the existing ground surface, and I've extruded a box with the base along the flowline elevs. I would like to be able to trim this box out of my surface, but SURFTRIM command is telling me I don't have valid objects.
    Please let me know if you have any ideas. I'm open to different approaches. Or if I didn't explain that well, I can try again.
    Thanks !
    2014-08
    447
    Default Re: Cut 3d Box Culvert From EG Surface
    I personally would make a new surface with a grading object then paste that surface into the old surface.
    You could also make a new surface from break-lines and paste that into the old one
    2004-06
    Slidell, Louisiana
    968
    Check out this video, it may help you.
    https://youtu.be/tQjQYuSeg0o
    2004-06
    Slidell, Louisiana
    968
    something like this? see attached image.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,096
    Quote Originally Posted by remi678731 View Post
    Pasting it into the old surface from a grading object surface which references the old surface may cause an error. Create a new surface object, paste the old surface and the new surface into the new surface object.
    2014-08
    447
    Hi
    I guess I didn't explain adequately you create the grading object then create a detached surface from the grading object. then delete the grading object (optional) then you have a separate surface that should paste well. I have used this process several times.
    2002-01
    jUSt Here (a lot)
    9,096
    Seems like more work than creating a new surface and paste your surface changes from grading along with the original surface. Grading Groups allow for the automatic surface generation via a check box and choosing the surface settings. If you need to revise your new changes, the link to the surface remains in the composite surface.
  1. Multiple Pipe Culvert Associativity
    Last Post: 2017-01-15, 11:48 PM
  2. 2013: creating or downloading a 64" 3D smooth steel culvert
    By kent.marcuson443718 in forum Revit Architecture - Families
    Last Post: 2013-12-30, 10:13 PM
  3. Culvert Design, Hydraflow express
    Last Post: 2013-04-24, 04:55 AM
  4. drain culvert
    Last Post: 2006-03-20, 11:29 PM
