Hello all,
please, is possible change justification of attribute with change visibility of dynamic block? More on the picture. Thank you very much for your answer. Ljustify_att.jpg
Hello all,
There is no way that I know of to do that.
You could have 3 different attributes, one in each visibility state. The one visible would be the only one available to be edited.
Hello, yes, i know about that. But i need to have same value in all attribute (value of last modified attribute).
You could add a User parameter to the block for the value and then set the default value of the three attributes to be a field that pulls the value of the parameter.
Hello, thanks for reply. I know about that, but if i do it in editor od block, regen to update fields doesn't work (in Drawing). If i do it in normal Drawing, so after update field works, but fields are same for all copy of this block
After editing a block definition with attributes in the block editor you need to run ATTSYNC to re-sync any inserted blocks with the revised definition. Or, delete the block and reinsert it.
Sorry, I finally had a moment to actually open the the block and poke around. I think I found the problem(s), 1 being duplicate tag names and 2nd the properties of the 4 attributes with fields.
I saw the other post on the Autodesk forum. I posted what I think is the solution and a fixed block there.
https://forums.autodesk.com/t5/dynam...7980819#M26361
