Thread: Sheet Set Fields
    2009-11
    Raleigh, NC
    580
    Default Sheet Set Fields
    When defining fields is there any distinct difference or reason for doing so by "CurrentSheet" & "CurrentSheetSet" as opposed to "SheetSet"?
    There doesn't seem to be any difference other than SheetSet mode seems to have a more definitive reassurance.
    Houston
    9,493
    3
    Default Re: Sheet Set Fields
    Current* will always refer to the current Sheet Set.
    If you copy the .DST file and .DWG files with fields defined this way, the reference is relative and will always refer to the "current" sheet set.
    When you point to "Sheet Set" and then pick a certain sheet set, and sheet, etc. - those references are static and will always point to what you've selected.
    If you don't consider the possible consequences, this can be dangerous. I've found fields in a DWG belonging to project "A", referring to sheet set properties for sheet set "XX" (in other words, a totally different sheet set with nothing to do with "A").
    This can happen easily with people copying and pasting objects from DWG to DWG.
    R.K. McSwain | CAD Panacea |
    2009-11
    Raleigh, NC
    580
    Thank you sir.
  1. 2016: Sheet set and fields
    By tim_newsome in forum AutoCAD General
    Last Post: 2017-01-24, 04:18 PM
  2. 2016: Sheet Set Fields
    Last Post: 2016-07-13, 01:42 PM
  3. 2011: AutoCAD 2011 Sheet Set Manager defaults fields to previous sheet set
    By Hatrick007 in forum AutoCAD Sheet Set Manager
    Last Post: 2016-05-06, 04:09 PM
  4. Sheet sets and Fields
    By Chuckyd67 in forum ACA General
    Last Post: 2005-05-06, 01:30 AM
  5. Sheet Set Fields
    By caddjockey2000 in forum AutoCAD Fields
    Last Post: 2004-10-08, 11:20 PM
