Thread: How to edit dimensions/parameters in AutoCAD using excel VBA
    2018-05
    Default How to edit dimensions/parameters in AutoCAD using excel VBA
    Hi!
    I have a drawing in AutoCAD and I have defined parameters there. Is it possible to edit the parameters using excel tables? I'm hoping to use command button(ActiveX) on spreadsheets and that will change the drawing to new parameters. For example, I have two circles and I want to change the diameters for those that I have in excel tables.
    Thank you for advance.
    2018-05
    Default Re: How to edit dimensions/parameters in AutoCAD using excel VBA
    I had to deal with the dimensional style AutoCAD, adjust the dimensions so that their appearance met the necessary requirements for the drawing. Now it's not just about the size of the text, is it? But also about its orientation and location, the accuracy of numerical values, the appearance of arrows, as well as the setting of remote / dimension lines. For myself, I found help in the projects and their advice had shown me that it`s enough to perform
    its configuration once and save the drawing as a template and then apply it in the work without losing time on editing the dimensions. Something like that...
    Turlock, CA
    6,412
    Pablo, I think the OP is looking for a vba solution, so your suggestion wouldn't work. Thanks
    C:> ED WORKING....
    LinkedIn
  1. Replies: 1
    Last Post: 2012-10-31, 03:34 PM
  2. cant edit iparts with excel
    By ed.w.cler in forum Inventor - General
    Last Post: 2009-11-20, 05:23 PM
  3. Replies: 1
    Last Post: 2009-04-29, 11:03 AM
  4. Unable to edit dimensions in AutoCAD 2009
    By christopherr in forum AutoCAD General
    Last Post: 2008-05-20, 08:50 PM
  5. AutoCAD dimensions to Excel
    By bartstienaers in forum AutoCAD Customization
    Last Post: 2005-11-09, 03:27 PM
