Results 1 to 8 of 8
Thread: ADD block preview into a table block table count creator
    Question ADD block preview into a table block table count creator
    Hey Guys!! I made this lisp by putting together some stuff i found on internet!! the only thing that i would like to do to make it perfect suitable to my own needs is to add the block preview (symbol) into the second collumn.. (witch is already empty as u can see on the Jpg file..)
    i would really apreciate if someane could help me here!!
    thanks
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: ADD block preview into a table block table count creator
    Design Center does a wonderful job of displaying all the blocks in a drawing resized and in alphabetical order. Try putting them all in into one drawing called legend and using a macro with the path and drawing name like:
    ^C^C^P(command "adcnavigate" "C:/Blocks/legend.dwg")
    It will open Design Center with your drawing making it easy to insert blocks, layers, linetypes, ect…
    Hi Tom,
    Sorry, i think i didnt make myself clear... i have a lisp that select some blocks on a drawing and then creates a table with count and atributtes of each block selected... what i need is to put the "preview" (in another words the block itself) on second collumn of the table... (take a look at the image attached on my last post.. there is a table created with the second collum empty.. theres where i would like to my block preview to go..)
    thank you very much, and sorry for not being that clear!! (sorry about my english, as well)
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Have you tried searching the forums? Maybe this thread has something that would work for you.
    2015-09
    5
    Quote Originally Posted by brunovinicius97767271 View Post
    Hi Tom,
    Look at code from this program by Lee Mac. I'm sure, you will find what you need.
    http://www.lee-mac.com/blockcounter.html
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Honolulu HI
    1,109
    (I revised this code)
    The block image is an interesting aspect of tables.
    I wrote some generalized functions to convert a table column to and from block images.
    I also included a test function that allows the user to select a table and convert one column (0 indexed) to symbols
    given the block name is the text in the cell.
    I also added some errortrapping (stability is important) and the toobjectconvert function is a simplified version of a toolbox
    function I use ALL the time...
    P=
    ;___________________________________________________________________________________________________________|
    ; Written By: Peter Jamtgaard C.E., P.E., S.E. copyright 2018 All Rights Reserved
    ; Any use by unauthorized person or business is strictly prohibited.
    ; Abstract: This library provides functions to convert cells in tables to block symbols
    ; Command Line Function Header List
    ;* C:TableCellSymbol
    ;* Command Line Function to test function to convert a cell in a table to a block symbol
    ; General Function Header List
    ;  Function, Arguments and Description
    ;* (ErrorTrap symFunction)
    ;* Function to trap errors. Returns value or T for success and nil for failure
    ;* (TableCellBlockNameToSymbol objTable intRow intColumn)
    ;* Function to change a cell in a table to a block symbol (given the text in the cell is a valid block name)
    ;* (TableCellBlockSymbolToName objTable intRow intColumn)
    ;* Function to change a cell in a table from a block symbol to a block name
    ;* (TableColumnToSymbol objTable intColumn)
    ;* Function to change a column in a table to block symbols (given the text in the table is a valid block name)
    ;* (ToObject value)
    ;* Function to convert a vla-object, entitynames, entsels, elists, handles or objectid's to a vla-object.
    ;$ Header End
    ; Function Headers
    ; Command Line Function to text Table Column To Symbol function
    (defun C:TableSymbolColumn ()
     (if (and (setq lstSelection (entsel "\nSelect Table: "))
              (setq objTable     (ToObject lstSelection))
              (= (vla-get-objectname objTable) "AcDbTable")
              (setq intColumn (getint "\nEnter Column to convert (0 indexed): "))
              (< -1 intColumn (vla-get-columns objTable))
    ; Function to trap errors. Returns value or T for success and nil for failure.
    (defun ErrorTrap (symFunction / objError result XYZ)
     (if (vl-catch-all-error-p
          (setq objError (vl-catch-all-apply
                         '(lambda (XYZ)(set XYZ (eval symFunction)))
                          (list 'result))))
      nil
      (if result result 'T)
    ; Function to change a cell in a table to a block symbol (given the text in the cell is a valid block name)
    (defun TableCellBlockNameToSymbol (objTable       ; Object Table
                                       intRow         ; Integer Row Index
                                       intColumn      ; Integer Column Index
                                       intObjectID    ; Integer Block Definition Object ID
                                       strBlockName)  ; String Block Name
     (and
      (setq colBlocks (vla-get-blocks (vla-get-document objTable)))
      (Errortrap (quote (setq strBlockName (vla-getText objTable intRow intColumn))))
      (Errortrap (quote (setq intObjectID (vla-get-objectID (vla-item colBlocks strBlockName)))))
      (Errortrap (quote (vla-setcelltype objTable intRow intColumn acBlockCell)))
      (Errortrap (quote (vla-setblocktablerecordID objTable intRow intColumn intObjectID :vlax-true)))
      (Errortrap (quote (vla-SetCellAlignment objTable intRow intColumn acMiddleCenter)))
    ; Function to change a cell in a table from a block symbol to a block name
    (defun TableCellBlockSymbolToName (objTable       ; Object Table
     (and
      (setq objTable (toobject objTable))
      (Errortrap (quote (vla-setcelltype objTable intRow intColumn acTextCell)))
      (Errortrap (quote (vla-setblocktablerecordID objTable intRow intColumn intObjectID :vlax-false)))
      (Errortrap (quote (vla-SetCellAlignment objTable intRow intColumn acBottomLeft)))
    ; Function to change a column in a table to block symbols (given the text in the table is a valid block name)
    (defun TableColumnToSymbol (objTable       ; Object Table
     (if (and
          (setq colBlocks (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
          (errortrap '(vla-put-RegenerateTableSuppressed objTable 0))
      (progn
       (repeat (- (setq intRow (vla-get-rows objTable)) 2)
         (setq intRow (1- intRow ))
    ;  Function to convert a vla-object, entitynames, entsels, elists, handles or objectid's to a vla-object.
    (defun ToObject (value / symType)
     (if (and
          (setq symType (type value))
          (or objDocument
              (setq objDocument (vla-get-activedocument (vlax-get-acad-object)))
          (or (= symType 'vla-object)
              (and (= symType 'ENAME)
                   (setq value (vlax-ename->vla-object value))
              (and (= symType 'STR)
                   (setq value (handent value))
                   (entget value)
                   (setq value (toobject value))
              (and (= symType 'LIST)
                   (= (type (car value)) 'ENAME)
                   (setq value (toobject (car value)))
                   (= (type (car value))  'LIST)
                   (= (type (cdar value)) 'ENAME)
                   (setq value (toobject (cdar value)))
              (and (= symType 'INT)
                   (= (strlen (itoa value)) 10)
                   objDocument
                   (setq value (errortrap (quote (vla-objectidtoobject objDocument value))))
         value
    (vl-load-com)
    AutomateCAD
    2012-12
    10
    Hello Peter!
    I came across your great lisp Table Magic once.
    May it be a solution for creating a blocks legend with block insert, attributes and count?
    If I remember your table was able to update the count too, am I right?
    Cheers!
    2012-12
    10
    Dear Peter,
    Your TableSymbolColumn.lsp does a true magic! I can use it on a table created with autocad Data Extraction. So for me this would be the quickest way to have a table with block miniatures, and all attributes in a table.
    I am only concerned now about the block alignment within tables cells, after I change Block autofit to "NO" and manually adjust the rotation of block in a cell. Block start to fall out of cells.
    Could a code module of TableMagic be used to update alignments of block within cells?
    Also, I wonder what happens when I add blocks, and new rows appear on the data extraction table. Shall the lisp be run again on that table to update appearance?
    Last edited by mikitari; 2019-04-19 at 10:36 AM. Reason: observations on lisp behaviour
  1. Replies: 8
    Last Post: 2020-10-07, 12:05 AM
  2. Replies: 1
    Last Post: 2017-01-15, 12:22 AM
  3. Block Table inside the Block Editor
    Last Post: 2013-11-12, 04:56 PM
  4. Replies: 0
    Last Post: 2013-10-31, 08:42 PM
  5. Block Attribute Table Values Dont' Appear in Block
    By stusic in forum Dynamic Blocks - Technical
    Last Post: 2011-12-27, 02:58 PM
