Thread: Legacy mvba files - won't run in V8i
    26
    Default Legacy mvba files - won't run in V8i
    I have 15 mvba files we've been using since version V8 (08.05.02.70). Currently on our Windows 7 boxes I've installed MS-J, V8, XM, and finally V8i (in that order) and these mvba files work fine in all versions. We are now moving to Windows 10 boxes and we are only installing version V8i. Of course these mvba files no longer work in V8i - which I think is a factor of missing the legacy vba installs from the earlier versions. I know the mvba works on Windows 10 as on my test machine I did install all the earlier versions and I have no problem, it's just the Windows 10 boxes with only V8i installed that have the problem. So - my question is, how would I get the legacy versions of VBA on the computers OR is there a way to upgrade the mvba files to the version of VBA that V8i uses? I did not create these mvba files and I'm only a novice at VB so I really need some help. I'm attaching one of the mvba files (along with the txt file) - if someone could help I would really appreciate it.
    Tanya
    Turlock, CA
    6,419
    Default Re: Legacy mvba files - won't run in V8i
    What program are you using? This forum is for VBA as used in AutoCAD.
    C:> ED WORKING....
    LinkedIn
    26
    OMG I'm so in the wrong forum - these files are being used in MicroStation - we also use AutoCAD and REVIT which is why I"m on this forum - disregard I'll remove this post
  1. Using mvba file
    By melissayed4401725022 in forum VBA/COM Interop
    Last Post: 2017-02-16, 05:23 PM
  2. Legacy MNS/MNU menus and lisp files
    By jon.154370 in forum AutoCAD CUI Menus
    Last Post: 2014-08-05, 11:39 AM
  3. i thought x.1 versions didn't upgrade legacy files?
    By Justin Marchiel in forum Revit Architecture - General
    Last Post: 2006-09-14, 02:14 PM
  4. Legacy cad detail files
    By tim.76721 in forum Revit Architecture - General
    Last Post: 2005-05-27, 02:23 PM
