Thread: automatic appload for release 14
    Default automatic appload for release 14
    I am using an ancient release (r14) but it seems like there was a lisp floating around
    that would automatically load selected lisps into drawings. I have a bunch of
    drawings that I need to edit and having the required lisps automatically load
    would make things easier.
    Thanks
    Rick
    2003-07
    561
    Default Re: automatic appload for release 14
    2 ways the easiest is make a script then it will do all the dwgs in one go, the other is to add your (load "mylisp") to acaddoc.lsp if it does not exist make it and save in your support path.
    open dwg1 (load "mylisp etc") close Y
    open dwg2 (load "mylisp etc") close Y
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Honolulu HI
    1,109
    Create an acaddoc.lsp or if that doesn't work... acad.lsp
    In it add these lines of code
    (load "myfirstlisproutine")
    (load "mysecondlisproutine")
    (defun s::Startup ()
     (alert "Running Startup")
    AutomateCAD
    Earth
    9,805
    There was no "Acaddoc.lsp" for R14, since R14 was not MDI capable.
    OP can use "Acad.lsp" or <menuname>.mnl, instead.
    (From the AutoCAD R14 CG Page 157)
    R.K. McSwain | CAD Panacea |
  1. Commandline Appload?
    By jonathanschade in forum AutoLISP
    Last Post: 2011-10-14, 05:40 PM
  2. Appload won't load
    By bboss in forum AutoLISP
    Last Post: 2010-06-04, 02:03 PM
  3. appload LISP
    By cma18 in forum AutoLISP
    Last Post: 2010-02-08, 06:23 PM
  4. APPLOAD
    By ifaller in forum AutoLISP
    Last Post: 2008-06-07, 08:45 PM
  5. Release Dates & Release Codenames
    By Buffeldrek in forum Inventor - General
    Last Post: 2006-09-22, 02:19 PM
