When I flipped the Alignment the existing grade line flipped......but the Proposed grade line needs to be flipped as well
By 'flipped' you mean you reversed the alignment stationing? or did you edit the alignment geometry?
I Reversed the stationing.......now the design profile I created is running in the opposite direction
Do I recreate it ??? or is there a function to change the direction
Try this.
Temporarily reset the stationing back to the way it was, then export the profile as an XML. 'Undo' to the point just before the temp station reset, then import the XML for the profile and allow it to overwrite.
Hi
under profile style or properties I can't remember which there is an option to reverse profile direction If I understand what you asking for
