Thread: EXTRACTING A FEATURE LINE ON MY CORRIDOR etw...
    2008-02
    North Liberty
    60
    Question EXTRACTING A FEATURE LINE ON MY CORRIDOR etw...
    ...gives me this (see image). Any ideas as to what is causing this rounded feature line along my vertical curve?
    This is happening where the road climbs up a hill(vertically) but still traveling in a straight direction between the PT and PC points don't mind that weird jog, i've fixed that and this still happens.
    Other info:
    this is a basic lane assembly
    the feature line is created on the ETW (P2) point of the assembly.
    2008-02
    North Liberty
    60
    Default Re: EXTRACTING A FEATURE LINE ON MY CORRIDOR etw...
    Not sure if this is a solution, but I INCREASED my Frequency from 5-ft to 20-ft and the bumps went away.
    "Whatever you are, be a good one."
    — Abraham Lincoln
  1. Just a Feature line and a corridor!
    Last Post: 2018-02-22, 11:31 PM
  2. 2016: Corridor feature line style
    By kwdsku in forum AutoCAD Civil 3D - Corridors
    Last Post: 2016-04-21, 06:08 PM
  3. 2016: Extracting Feature line from a Corridor
    By tim_newsome in forum AutoCAD Civil 3D - Corridors
    Last Post: 2015-10-09, 07:25 PM
  4. Corridor feature line set
    Last Post: 2013-08-12, 01:45 PM
  5. Unir corridor con feature line.
    By michel_alcolado in forum Español - AutoCAD Civil 3D
    Last Post: 2010-06-23, 02:14 PM
