Thread: hello, any one can help me make multiple leader match same angle
    Default hello, any one can help me make multiple leader match same angle
    hello, any one can help me make multiple leader match same angle, because i have a lot of leader but leader angle not same , but my job need to arrange all leader make same angle, how can i do ??
    THX
    2015-11
    Default Re: hello, any one can help me make multiple leader match same angle
    Hi,
    You can use the mleadersalign.lsp (work in model space only). Set UCS to new alignment and ran the lisp. Just remember to change your UCS back!!
    Thanks
    Hannah-Marie
    in other post, i found this lisp, but i only need same angle, no need same height, but i don't know how to change this lisp, anyone can help me, pls
    and i need to change is LEADER, not multileader, i only need to arrange leader angle , no need same height, anyone can help me
    (defun c:foo (/ _pts a d e el epts i mp n o p p2 s x y)
      ;; RJP 03.27.2018
      ;; Aligns 'old school' 3 pt leaders matching angle of leader and fixes offset distance of horizontal landings
      ;; ***The bottom most leader is the one matched***
      ;; Far from perfect, but better than doing it manually
      (defun _pts (e)
        (mapcar 'cdr
    	    (vl-remove-if-not '(lambda (x) (= 10 (car x))) (entget e))
      (cond
        ((and (setq s (ssget ":L" '((0 . "leader"))))
    	  (setq
    	    s (vl-sort
    		(mapcar	'(lambda (x) (append (list x) (_pts x)))
    			(vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
    		'(lambda (a b) (< (cadr (last a)) (cadr (last b))))
    	  (setq d (/ (distance (last (car s)) (last (last s))) (length s)))
    	  (or (setq
    		i (getdist
    		    (strcat "\nEnter spacing for horizontal leader[<"
    			    (vl-princ-to-string d)
    	      (setq i d)
    	  (setq e (car s))
    	  (setq s (cdr s))
         (setq a (angle (car (setq epts (cdr e))) (cadr epts)))
         (setq y (last epts))
         (setq n 1)
         (foreach l	s
           (setq o (vlax-ename->vla-object (car l)))
           (setq p (cdr l))
           (cond ((setq mp
    		     (inters (car p)
    			     (polar (car p) a 1e-2)
    			     (setq p2 (list (car y) (+ (* n i) (cadr y)) 0.0))
    			     (polar p2 0.0 1e-2)
    			     nil
    	      (vlax-put	o
    			'coordinates
    			(apply 'append (list (car p) mp p2))
    	      (setq n (1+ n))
      (princ)
    2005-06
    CORDOBA-ARGENTINA
    275
    Please upload your true DWG.
  1. Replies: 3
    Last Post: 2018-03-28, 01:33 PM
  2. Dim angle in Leader
    By fredacx363311 in forum AutoLISP
    Last Post: 2013-03-05, 04:38 PM
  3. multiple connection point for leader tails when using a multi-leader
    By jschraud228486 in forum AutoCAD Annotation
    Last Post: 2010-06-16, 01:42 AM
  4. Angle of leader segment
    By cadconcepts in forum AutoLISP
    Last Post: 2009-03-03, 06:32 AM
  5. Line and Text Angle Match
    By BCrouse in forum AutoCAD General
    Last Post: 2006-03-10, 11:15 AM
