Results 1 to 10 of 12
Thread: Change alignment direction arrow
    2004-06
    Slidell, Louisiana
    973
    Question Change alignment direction arrow
    where are the settings to change the alignment direction arrow. i have found the place to turn them off/on in the display tab.
    but i cannot fine any other settings, i.e. arrow style etc.
    Earth
    9,809
    Default Re: Change alignment direction arrow
    Are you talking about the arrow that is part of the Alignment Style (and not the Alignment Label Styles)?
    R.K. McSwain | CAD Panacea |
    2004-06
    Slidell, Louisiana
    973
    you got me there, i'm not sure. that's part of my problem. it shows up on the alignment at the mid point of each straight segment.
    edit: it seems to be on the alignment style.
    Earth
    9,809
    Yes, and AFAIK, there is no way to change its properties.
    2015-10
    Central New Jersey
    439
    There are a few settings for the arrow at the bottom of the Markers tab of the alignment style but only some of the settings have any effect. The size value works but not the type of arrow. The arrow type seems to follow the leader arrow head set for the current dimension style. Switching to a different dimension style as the default changes the arrow head style used for the alignment. .... weird.
    Based on Civil 3D 2015, sp3.
    Earth
    9,809
    Quote Originally Posted by MMccall View Post
    I did not see that on the Markers tab. Thanks!
    Okay, so it works the same way as you describe in Civil 3D 2017, and Civil 3D 2018, and Civil 3D 2019...........
    Some bugs never get fixed.
    2004-06
    Slidell, Louisiana
    973
    I can't seem to duplicate this. Can you explain a little further in detail?
    I changed the arrowhead in the current dimstyle, regen'd, but nothing changed. i am using 2016
    Earth
    9,809
    Change the "Leader" arrowhead type of the current Dimstyle (make sure you're not changing a style override).
    Then Regen.
    2004-06
    Slidell, Louisiana
    973
    Then Regen.
    AHH, the "Leader" arrowhead type.....that did it. Thanks. Nothing like burying it deep.
    Earth
    9,809
    Yes, I suppose if you want to control that symbol via Dimstyle, you'll have to make sure you don't change the *current* dimstyle.
  1. 2017: alignment direction
    By rmk in forum AutoCAD Civil 3D - General
    Last Post: 2018-01-08, 03:20 PM
  2. 2015: Alignment Direction
    By tim_newsome in forum AutoCAD Civil 3D - Alignments
    Last Post: 2016-05-27, 06:45 PM
  3. 2015: Revit LT 2015 - span direction arrow
    By dan.price in forum Revit - LT Support
    Last Post: 2014-08-08, 05:56 PM
  4. wrong north arrow direction
    By elsabrosoweb in forum AutoCAD Civil 3D - General
    Last Post: 2013-02-27, 08:09 PM
  5. Can't Add a Direction Arrow to Style
    By kayak in forum AutoCAD Civil 3D - General
    Last Post: 2011-07-26, 07:10 PM
