Thread: How to update content of the MText?
    Default How to update content of the MText?
    Hello everyone!
    I have a question. I have a method wich creates Mtext with а list of block names. I need that every time when I insert new block in drawing and call my method the list in Mtext wil be updated and name of block wil be added to list. Now it only adds new Mtext but I need only update existing Mtext without insert new MText. I dont know how realize update.
    Turlock, CA
    6,409
    Default Re: How to update content of the MText?
    It would help if you posted the code you already have. Don't forget to enclose it in code tags. Use the Go Advanced button and the # button.
    C:> ED WORKING....
    LinkedIn
    Here is my code
    public static List<string> GetAllFormats () // Получает все примененные форматы для подсчета их количества
                   Document doc = Application.DocumentManager.MdiActiveDocument;
                   Editor ed = doc.Editor;
                   Database db = doc.Database;
                   List<string> listOfFormatsInDrawing = new List<string>();
                   using ( Transaction tr = doc.TransactionManager.StartTransaction() )
                        BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                        if ( bt.Has("MainTitle") )
                             foreach ( ObjectId btrId in bt )//bt набор btrRecord то есть по своей сути уже коллекция!
                                  BlockTableRecord btr = tr.GetObject(btrId, OpenMode.ForRead) as BlockTableRecord;
                                  if ( btr.Name.Contains("Title"))
                                       ObjectIdCollection brIdCollection = btr.GetBlockReferenceIds(false, true);// собрать все Id от BlockReference из BlockTableRecord в коллекцию
                                       foreach ( ObjectId brId in brIdCollection )
                                            BlockReference br = tr.GetObject(brId, OpenMode.ForRead) as BlockReference;// получить все BlockReference
                                            AttributeCollection attrIdCollection = br.AttributeCollection;// собрать все Id от атрибутов из BlockTableRecord в коллекцию
                                            foreach ( ObjectId idAttRef in attrIdCollection )
                                                 AttributeReference att = tr.GetObject(idAttRef, OpenMode.ForRead) as AttributeReference;
                                                 if ( att.Tag=="Format" )
                                                      pageFormat=att.TextString;
                                                      listOfFormatsInDrawing.Add(pageFormat);
                        tr.Commit();
                   return listOfFormatsInDrawing;
              [CommandMethod("CreateFormatList")]
              public static void CreateFormatList ()//Создает список всех примененных в чертеже форматов
                   Document acDoc = Application.DocumentManager.MdiActiveDocument;
                   Database acCurDb = acDoc.Database;
                   GetAllFormats();
                   List<string> formatInCurrentDrawing =GetAllFormats();
                   formatInCurrentDrawing.Sort();
                   string resultString= string.Join("| ", formatInCurrentDrawing);
                   // Start a transaction
                   using ( Transaction acTrans = acCurDb.TransactionManager.StartTransaction() )
                        // Open the Block table for read
                        BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable;
                        BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl[ BlockTableRecord.PaperSpace ], OpenMode.ForWrite) as BlockTableRecord;
                        // Create a multiline text object
                        using ( MText listOfFormats = new MText() )
                             listOfFormats.Location=new Point3d(-185, -15, 0);
                             listOfFormats.TextHeight=10.5;
                             listOfFormats.Attachment=AttachmentPoint.TopLeft;
                             listOfFormats.Width=182;
                             listOfFormats.Contents=$"This drawing contains {resultString}";
                             listOfFormats.Layer="-10-Viewports";
                             acBlkTblRec.AppendEntity(listOfFormats);
                             acTrans.AddNewlyCreatedDBObject(listOfFormats, true);
                   acTrans.Commit();
  1. 2014: no thumbnails for 2014 content after batch update
    By geistwolke in forum Revit Architecture - Families
    Last Post: 2014-07-14, 07:24 PM
  2. GetBoundingBox MText actual content only
    By mailmaverick361505 in forum AutoLISP
    Last Post: 2013-12-11, 11:24 AM
  3. Content center update
    By bub4 in forum Inventor - General
    Last Post: 2009-09-10, 01:21 AM
  4. Update Shared Content with WU2?
    By mibzim in forum Revit Architecture - General
    Last Post: 2008-10-02, 10:18 AM
  5. Differences in content of Mtext returned
    By jmcshane in forum AutoLISP
    Last Post: 2007-06-14, 08:50 PM
Tags for this Thread
